My Car Has Cruise Seizures - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: My Car Has Cruise Seizures (/showthread.php?tid=10189) Pages:
My Car Has Cruise Seizures - ANTHONYD - 04-11-2006 Heavily modded. My Car Has Cruise Seizures - hardk0re - 04-11-2006 I guess telling them the fuel pump isn't modded wouldn't help eh? My Car Has Cruise Seizures - Flofocus - 04-11-2006 hardk0re,Apr 10 2006, 11:56 AM Wrote:I guess telling them the fuel pump isn't modded wouldn't help eh? Your SC shouldnt affect a fuel pump recall. If it was warranty work, then yeah, you would get that denied, but because this is a safety/drivability issue with or without a SC, they should change it. I know the new fuel pump made a world of difference in drivability with my car. My Car Has Cruise Seizures - hardk0re - 04-12-2006 I've disabled EGR and removed it, no remedy for the problem. I've got a task list of stuff i'm gonna fix sometime this weekend as long as I get 1 day to work on this thing and get all this crud fixed. I am really aiming for a shotgun approach here and that i'll hit the problem somewhere in here...at ths point I don't care what the problem is...as long as its gone... To Help The Problem: - Remove remaining EGR sensors since its dissabled anyway - Replace 1st O2 Sensor - Replace Bosch Bypass Valve - Replace throttle body gasket - Do Engine Ground Mod - Change Plugs Again - Fix Exhaust Leaks - Do Compression Test (grasping at straws) Parts Needed: O2 Sensor Throttle Body Gasket New Plugs Exhaust Gaskets Bosh Bypass Valve Zip Ties 4 AWG Wire (few feet) For Sale Sign My Car Has Cruise Seizures - Blackzx3 - 04-12-2006 Now that your just part changing to attempt to remedy the solution, wouldn't it be cheaper and easier to take it to a shop and get them to work out the problem. My Car Has Cruise Seizures - hardk0re - 04-12-2006 The new part cost here is actually pretty low with the exception of the o2 sensor. I've been down this road before, ford will happily change something at a cost, if it doesn't work blame some aftermarket part or happly change another part for a cost. I could easily spend over $500 at the dealer and not have the issue resolved. If I do all this myself then take it in, I can easily say done it to 90% of what they got to say, and it only cost me a faction of the cost. The car isn't throwing ANY codes which makes it tough.... My Car Has Cruise Seizures - NOS2Go4Me - 04-12-2006 That's weird man. Never heard of that level of grief and having the ECU NOT throw a code. Hell, I threw a code running out to your place this winter past just doing 160 :D My Car Has Cruise Seizures - schade - 04-13-2006 i've got a spare set of the colder motorcraft plugs incase you can't get your hands on a set My Car Has Cruise Seizures - hardk0re - 04-17-2006 Well, I spent one day fixing up some loose ends, fixed all my exhaust leaks, coolant leaks. One thing I did add was the ground wire upgrades and power wire upgrades, that seemed to reduce the problem a little, its more or less now what could be compressor surge which is totally acceptable. Anyway for those that have any problems, this upgrade is only maybe 10-20 dollars, definetly worth the trouble. The car runs like a champ...for now. |
