Powerworks Bbk - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Powerworks Bbk (/showthread.php?tid=10530) |
Powerworks Bbk - STFUN - 03-15-2006 PerfectSaiyan,Mar 14 2006, 08:04 PM Wrote:so the powerworks kit has an optional BBK TB or does it come standard? The Powerworks kit is supplied with a BBK throttle body as standard, but I have the Big Boost Kit running 14 to 15 psi boost. The SC snout and pulley wheel was initially destined for Mitch's car, but he graciously let me have it :D Powerworks Bbk - euro - 03-16-2006 With, ported head, cams, exhaust, cam gears. Just bolt on it's only 209whp, I want 300whp, nothing less! It's PW or precision turbo right now, but I got time to pick. Powerworks Bbk - ZX3TUNING - 03-16-2006 euro,Mar 15 2006, 03:34 PM Wrote:With, ported head, cams, exhaust, cam gears. Just bolt on it's only 209whp, I want 300whp, nothing less! It's PW or precision turbo right now, but I got time to pick.umm, bolt on a PW kit and it's 220fwhp add in a full exhaust and it's about 225-230fwhp add in our cams and it's 250fwhp add in a better tune and you are close to 270fwhp or even more if you can push the timing on better gas add in a BBK and you *SHOULD* be able to crack the 300fwhp mark without interior motor work add in a built motor and flowed head and who knows... Powerworks Bbk - STFUN - 04-06-2006 Well after suffering from a toasted clutch, it was back to the workshop for a Fidanza flywheel and clutchmasters Stage IV clutch, but power was down due to the ancillary belt having stretched. So back to PE it was for a further belt change and a tweak of the mapping for the idle control. Now running a healthy 309BHP at 0.9 Bar boost again :D Powerworks Bbk - ZX3TUNING - 04-06-2006 ![]() ![]() Powerworks Bbk - sweetg - 05-10-2006 what kind of head do u have installed? Powerworks Bbk - PerfectSaiyan - 05-10-2006 mitch i want some cams :) then my focus would be pushing 250 as well :) Powerworks Bbk - Drivesthebeast - 05-10-2006 DAMMIT!!! You're all making me wanna put a big dent in my line of credit really bad now! Thx! :P Powerworks Bbk - Honkeytonk Monkey - 06-01-2006 ZX3TUNING,Mar 16 2006, 03:54 AM Wrote:euro,Mar 15 2006, 03:34 PM Wrote:With, ported head, cams, exhaust, cam gears. Just bolt on it's only 209whp, I want 300whp, nothing less! It's PW or precision turbo right now, but I got time to pick.umm, bolt on a PW kit and it's 220fwhp So Mitch... With what I have on the car now (Jay's old car from your site), cam gears, UDPs, 4-1 header, coil/wires, copper plugs, flex, 2.5" magnaflow, 80mm MAF, FRPP cylinder head, and hypothetically speaking, water/meth injection, your cams, pistons and rods... what would it net me, and would you recommend it over a turbo setup? Powerworks Bbk - STFUN - 06-01-2006 sweetg,May 9 2006, 05:24 PM Wrote:what kind of head do u have installed? I have a gasflowed, ported and polished ST170 head :D Powerworks Bbk - ZX3TUNING - 06-03-2006 Honkeytonk Monkey,May 31 2006, 08:14 PM Wrote:So Mitch... Umm, didn't know about the FR head or MAF but... depending on the compression of the pistons, how the water meth injector was setup you could see anywhere from 270-300+... to many varriables to give you a solid number. as for recommending over a turbo, at the pirce of the PW kit right now, i'd have a hard time recommending anything over it aside from a functioning Flux-capacitor! ;) Seriously though, you will have a hard time finding a more solid kit than the PW kit. Power potential is great as we are starting to prove. We just got our Short block back from the machine shop; Blue Printed and Balanced to 9000rpm, custom specs throughout. Just finished the tranny rebuild with the Quaife and 4.06 Final drive. BBKs had to be sent back to PW due to shaft issues. our ported head is waiting to be port matched to the PW upper intake manifold and at the same time, port the PW upper intake. Custom 321 SS header with 3" collector and Burns Stainless Merge collectors and full 3" SS exhaust is being designed and built right now. New Clutchnet Clutch and flywheel is sitting beside me. revised intake track and custom cold air feed designed waiting to be built once car is running.... a bunch of other little tricks are instore for this project... We are very confident to see ~300fwhp and ~260lb/ft out of this setup on 94oct, but would not be surprized with more. :P Goals are to retain the stock PW intercooler, stock Rad, run on pump 94, and daily drivable. Powerworks Bbk - Honkeytonk Monkey - 06-08-2006 Where do you guys find pump 94? In Saskatchebush I've never found anything over 92 and that was the ethanol blend stuff at Mohawk. I'm moving to Edmonton tomorrow, anyone from there give me any ideas where to find it? Powerworks Bbk - ZX3TUNING - 06-08-2006 We get 94 from Chevron and some Petro-Canada stations.... Powerworks Bbk - naz - 06-08-2006 wooow. nice!!! so that is the sc kit, throttlebody, and a port/polished head and a good tune? anything else? what comes in the kit btw? bigger injectors, chip? that's very nice!! Powerworks Bbk - ZX3TUNING - 06-09-2006 yeah, those numbers were on a ST170(SVT) engine, flowed head, BBK, PW SVT kit and a custom tune with a standalone ECU and some exhaust work. Powerworks Bbk - STFUN - 06-15-2006 Don't forget the Random Technologies Sports CAT Mitch :D naz Apparently my car was the first SVT/ST170 to be fitted with the Big Boost version of the Powerworks kit. We had a few issues to resolve, mainly with the drive belt and tuning (Omex 710 ECU), but has since been faultless. Omex has a couple of bugs in the software, which only affect the car occassionally around the 3200rpm mark (a "burp"), but allowed for a dedicated tune for the car. Powerworks Bbk - Jays2000ZX3 - 06-17-2006 LOL BBK in this case is refering to the Big Boost Kit, not the BBK Throttle body..LOL!! :rolleyes: Powerworks Bbk - theMeasure - 06-20-2006 BBK the TB company, not Big Boost Kit as is avail. for the Jackson racing supercharger kit... Powerworks Bbk - ZX3TUNING - 06-20-2006 Actually this car has the PW BIG BOOST KIT as well as the BBK TB iirc... Powerworks Bbk - STFUN - 06-21-2006 ZX3TUNING,Jun 20 2006, 08:51 AM Wrote:Actually this car has the PW BIG BOOST KIT as well as the BBK TB iirc... Yup, you remember correctly Mitch :D By the way, the car also hit 1.2BAR (16.8psi) boost last week :D |
