F2's Twin Turbo Setup - Printable Version
+--- Thread: F2's Twin Turbo Setup (/showthread.php?tid=11232)
Pages: 1 2
F2's Twin Turbo Setup - mpcv2000 - 01-19-2006
ZX3TUNR,Jan 18 2006, 01:10 PM Wrote:The exhaust manifold is on the back of all MK2 focus's
[right][snapback]165675[/snapback][/right]
I'm not familiar with Focuses yet and I never seen a MK2 either, I guess it's not available to the North American Market. I'll do a searh to get more info.
Thanks !
F2's Twin Turbo Setup - nass - 01-19-2006
Thanks !
[right][snapback]165781[/snapback][/right]
MK2 just signifies that it is a new body/platform. pre 2005 are MKI ( MK1 ) 2005 + are known as MKII ( MK2 ) cause of the new body style.
Ok got it , it's like the SN95 Mustangs , platform they used it from 94 to 04.
F2's Twin Turbo Setup - ZX3TUNING - 01-19-2006
last i checked this car ran and is probably going to be at the FocusShootout in april.
also, overkill or not, this was an exersize in fabrication skills of a shop.
the ability to build something this wild is not something many can do, usefull or not, it's impressive.
rob doesn't like anything that isn't built for purpose... i'm not surprized he doesn't like this.
F2's Twin Turbo Setup - P-51 - 01-21-2006
ZX3TUNING,Jan 19 2006, 04:49 AM Wrote:last i checked this car ran and is probably going to be at the FocusShootout in april.
[right][snapback]165810[/snapback][/right]
It does not "run" in the true sense of the word. It will idle, and I believe it can even move under it's own power to get from the trailer to the carpet and back. But that's it.
But that is more of a testament to the power of Ford's EEC than it is to their fabrication skills. I've "run" my car with a charge pipe popped off, and the turbo drawing through the MAF and venting to atmosphere.
I've "run" my car with the MAP sensor broken for the Pectel, driving while using the + and - keys on the global fuel trim to match the throttle setting I needed.
Yeah, it's a decent exercise in packaging and fabrication. I'll give it that. I probably wouldn't have said much if they had just said "it's a show car". But instead they ran their mouths, and talked about how they'd have it running shortly after SEMA was over. It's been months, and... nothing.
I just realized the twin intercooler thing... lame.
And the intake/exhaust reversal thing doens't have anything to do with Mk1 vs. Mk2... it's the Duratec engine that is reversed. That engine has been in Foci in Cali since 2003.
F2's Twin Turbo Setup - ZX5focused - 01-24-2006
quick question, how much power do you think its gonna have to make, to get the 2 turbos running efficiently??
like i undestand how the whole turbo thing works and everything, but its gonna need to be pushing alot of air in (which it obviously can) to be pushing enough exhaust gases through the turbos to keep the spinning efficiently. without the tuning dead on and always revving high, that thing will have huge lag.
