Air Intake? - Printable Version
+--- Thread: Air Intake? (/showthread.php?tid=15343)
Pages: 1 2
Air Intake? - dmcisaac - 04-25-2005
This one
or
This one
incase that thing doesn't work /\
Air Intake? - ZX5focused - 04-25-2005
dmcisaac,Apr 24 2005, 03:58 PM Wrote:This one
or
This one
[right][snapback]104100[/snapback][/right]
if you have a zetec, which im pretty sure you do, the second one is the one you want.
Air Intake? - focusonthis88 - 04-25-2005
or
This one
[right][snapback]104101[/snapback][/right]
I just bought a Bomz, and im going to buy a K&N Filter and I'll let you guys know how it goes.
Air Intake? - 2001 ZTS - 04-25-2005
I'm always different.
My 'cheap' set up is SVT intake snorkel, bottom half of a SVT airbox and K&N panel filter. If I can come across one I'll add an "add on duct" to the resonator opening.
Air Intake? - Honkeytonk Monkey - 04-25-2005
I used a K&N filter and using a small section or 3" alluminum mandrel bent polished exhaust pipe attached it to the MAF sensor. I welded in a small outlet for the breather tube to attach to as well. Sounds much better (although kinda fart pipe-ish) and throttle response seems a bit better as well. I'm happy and it cost me nothing since I had the Filter from my last vehicle.
Air Intake? - guilty - 04-25-2005
dmcisaac,Apr 24 2005, 01:58 PM Wrote:This one
or
This one
You have to watch out for the term SOHC (single overhead cam) which refers to the SPI engine in the base model sedans/wagons. The Zetec is DOHC (dual overhead cam).
Also from the links you posted, the first one was a short ram style intake and the second is a cold air intake (CAI). The short intakes are just an elbow off your throttle body, a pipe, and then a cone filter. The CAI unit runs piping all the way down and around the engine to hang the filter closer to the ground and the front bumper. The advantage of the CAI is that it isnt pulling the hot engine-bay air into the intake, disadvantages include driving through a deep puddle, sucking up water and hydrolocking your engine.
