Bad Idle - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Bad Idle (/showthread.php?tid=15871) Pages:
Bad Idle - BerinG - 03-04-2005 It might be caus you're a girl.. might :ph34r: No seriously you guys think of all the big things.. What I would do first, is unplug the battery for 10 minutes.. replug the battery, go for a drive.. it might act up a bit for the first few blocks since it has to learn the mods in conjuction with the weather but it'll get used to it.. it might be just used to the summer settings and since its pretty cold, it won't learn back "that" far i think.. i had that problem at the begining of the winter.. that fixed it.. if not.. try putting your stock airbox.. could be too cold for a CAI... and water could be another problem like someone else mentioned Bad Idle - NOS2Go4Me - 03-05-2005 I dunno about too cold for a CAI, unless you're sucking pounds of snow up it. My homegrown short ram has been flawless in -20 and worse weather so far. I think my setup is the same as j3rt's. Maybe your alternator is starting to take a nosedive? Bad Idle - mysterygirl - 03-18-2005 I honestly think it's the car starter I had installed. The car is pretty new so I can't see how the plugs are bad. I reset the ecu thingy still nothing. My CAI is an Injen one so it's not open to water or snow. Also my car stalled and turned off a few times too, so it'sot just a bad idle...it stalls! Another reason why I think it's the starter, is when I turned my car off.... my stereo was still playing. I had to pull the battery to turn it off. Gonna get the installer to check it out, and when it gets warmer i'll check plugs and MAF. P.S. Who's Natasha? Bad Idle - NOS2Go4Me - 03-18-2005 Ouch, yes car starters can be a serious pain in the ass when installed incorrectly. Who installed yours - the dealer, or an aftermarket shop? Bad Idle - ANTHONYD - 03-19-2005 Sounds electrical. Have the installed starter worked over again. |
