Sticking Fc Tb - Printable Version
+--- Thread: Sticking Fc Tb (/showthread.php?tid=16481)
Pages: 1 2
Sticking Fc Tb - Chromey - 11-26-2004
Ok This should fix the problem.
Screw in the idel(SP) Screw a few turns.
Sticking Fc Tb - SLIP STREAM SVT - 11-26-2004
Chromey,Nov 26 2004, 12:31 AM Wrote:Ok This should fix the problem.
[right][snapback]71606[/snapback][/right]
what's that?? can someone show me a pic of this? so i can try this out before go and complain for teh 5th time about the same thing, i think they are getting annoyed with me already!
Sticking Fc Tb - S2 - 11-26-2004
There is a little screw that acts as a stopper for the throttle cable and when you move it ahead it will keep your idle higher (in the RPM range). If you back it off, the idle will go lower. Not sure if that would have anything to do with the sticking, I know on mine, it would be a bit tougher to get initially going but it was fine after it warms up, etc.
Sticking Fc Tb - ANTHONYD - 11-26-2004
My stock TB used to do that.
I just turned the idle cable a touch and it worked fine. no more sticking. ;)
Sticking Fc Tb - Chromey - 11-27-2004
The only reason I say turn it in is so the Throttle Flap cant close completely around the edges, Hense nothing to stick on.
Now if that dosent fix the problem then its not your throttle body.
Sticking Fc Tb - dad - 11-27-2004
Chromey,Nov 26 2004, 07:45 PM Wrote:The only reason I say turn it in is so the Throttle Flap cant close completely around the edges, Hense nothing to stick on.
[right][snapback]71807[/snapback][/right]
only problem with that is that you will notice a slower return back to idle....the engine as it winds down is still getting air...the MAF see this ....tells the computer and the car gets more fuel...thus kinda slowing the process down...
I tried this solution when my stock cat was on its way out and the car would not idle properly...that is what happened...when I put the high flow in the same thing contiued untill I set the flaper in the throttle body all the way back to closed....end of problem....
my 2 cents
