Stripping, Painting, And Installing Zx3 Skirts - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Appearance (//www.focuscanada.net/forum/forumdisplay.php?fid=21) +--- Thread: Stripping, Painting, And Installing Zx3 Skirts (/showthread.php?tid=1974) Pages:
Stripping, Painting, And Installing Zx3 Skirts - Focus man. Focus. - 03-01-2009 QWKRN-U,Feb 28 2009, 09: Wrote:Try not to use too coarse of sand paper on your skirts, it will turn the plastic "furry" when you try to prime it. I would use 220-240grit paper to feather out the chips and scratches, as long as the rest of the paint is in good shape and not pealing or anything I would just scuff it with 320 and prime it. For primer use Plastic coat grey self etching primer, I find it works very well for a rattle can primer. Ill try and get a part # for the primer. Then scuff them with 400-600 grit paper and top coat them. That was the info I was looking for. Thanks man! Stripping, Painting, And Installing Zx3 Skirts - QWKRN-U - 03-02-2009 NP man, glad I could help. Thats what I do for living. Ill get the part # for that primer tomorrow when Im at work. I highly recomend you give it a try. Stripping, Painting, And Installing Zx3 Skirts - QWKRN-U - 03-03-2009 The part # is 470 and its Plasti-kote grey etching primer. I get it from NAPA, not sure if CT sells it or not. Stripping, Painting, And Installing Zx3 Skirts - Scorcher000 - 03-03-2009 Lol he works at NAPA. Stripping, Painting, And Installing Zx3 Skirts - QWKRN-U - 03-03-2009 LMAO that should make it pretty easy to get. :lol: Stripping, Painting, And Installing Zx3 Skirts - Focus man. Focus. - 03-09-2009 LOL I used to work at NAPA. Now I work for Castrol. But I still have my connections. Well I have started on the prep and things are going well. Slow but well. I am hand sanding everything and the 3M paper seems to be getting clogged up quickly. Although by bending the paper it just falls off. Here is my progress so far. Before After I do have a lot more to do but it is coming along nicely. I should be able to get these on at some point this spring if everything goes as planned. Stripping, Painting, And Installing Zx3 Skirts - konafocuswrc - 03-09-2009 i have that exact side skirts pulled out from my car.. non painted...it is missing front portion.. you can pick it up if you want to.. Stripping, Painting, And Installing Zx3 Skirts - Focus man. Focus. - 03-09-2009 konafocuswrc,Mar 8 2009, 06:43 PM Wrote:i have that exact side skirts pulled out from my car.. You have a pair of skirts for a ZX3 that aren't painted, only missing the front caps? I feel like I just wasted an afternoon sanding. I will take them! Where are you located? Markham or something right? Stripping, Painting, And Installing Zx3 Skirts - SL8RZZX3 - 03-09-2009 I'm pretty sure you'd still have to sand them as they have a texture to them that would have to be smoothed down before painting Stripping, Painting, And Installing Zx3 Skirts - konafocuswrc - 03-09-2009 but still easier to sand down textures.. i m in toronto king + dufferin..or etobicoke sherway garden.. Stripping, Painting, And Installing Zx3 Skirts - meford4u - 03-09-2009 QWKRN-U,Feb 28 2009, 09: Wrote:Try not to use too coarse of sand paper on your skirts, it will turn the plastic "furry" when you try to prime it. I would use 220-240grit paper to feather out the chips and scratches, as long as the rest of the paint is in good shape and not pealing or anything I would just scuff it with 320 and prime it. For primer use Plastic coat grey self etching primer, I find it works very well for a rattle can primer. Ill try and get a part # for the primer. Then scuff them with 400-600 grit paper and top coat them.This guys advice...............right on the $$$ Stripping, Painting, And Installing Zx3 Skirts - QWKRN-U - 03-11-2009 Thanks mefordf4u. Keep us updated with pics, even if you use the other skirts. Your doin a fine job on the yellow ones though. Stripping, Painting, And Installing Zx3 Skirts - Dimitri - 03-11-2009 Can you save some time by renting a hand-sander from Home Depot? Or would that sander be too rough on the skirt? Just trying to find a way that would make it easier for you. Stripping, Painting, And Installing Zx3 Skirts - QWKRN-U - 03-11-2009 Yup a dual action palm sander would work, they are fairly cheap too under $40. |
