New Lower Stress Bar From Focussport - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: New Lower Stress Bar From Focussport (/showthread.php?tid=3048) Pages:
New Lower Stress Bar From Focussport - mister_bin - 07-06-2008 ^^ I wish i could install i rear stress bar in my car it would really help in stiffening things up.. Cant have everything i suppose. New Lower Stress Bar From Focussport - ZTWsquared - 07-06-2008 mister_bin,Jul 5 2008, 11:44 AM Wrote:^^ I wish i could install i rear stress bar in my car it would really help in stiffening things up.. Cant have everything i suppose.It would be ideal if someone were to design one that could be easily removed ... bolt it on for track days, take it off when you need the haulage space. How hard could that be? New Lower Stress Bar From Focussport - Scorcher000 - 07-08-2008 It's very possible if you can weld. take the original bar bolt it in and meassure the cut on both side close enough to hide the ends. on each end weld a smaller short pipe on it so it can go inside the car and mark and drill hole bolt it up with a Grade A and TA DA. New Lower Stress Bar From Focussport - Spinal - 07-08-2008 ZTWsquared,Jul 5 2008, 11:22 AM Wrote:if you're talking about the rear stress bar it is basically just bolt-in. theres only 2 bolts holding it on either side, if you really wanted to take it out it'd only take a couple minutes. also it hardly takes up any space in the hatch it only sits about 6 inches or so from the back seat, and it works amazing for holding a sub in place.mister_bin,Jul 5 2008, 11:44 AM Wrote:^^ I wish i could install i rear stress bar in my car it would really help in stiffening things up.. Cant have everything i suppose.It would be ideal if someone were to design one that could be easily removed ... bolt it on for track days, take it off when you need the haulage space. How hard could that be? New Lower Stress Bar From Focussport - malim - 07-08-2008 Using bungee cords XD :)) jk Very nice mod actually with some noticable difference i guess. o. O New Lower Stress Bar From Focussport - thenorm - 07-10-2008 mister_bin,Jul 3 2008, 11:02 AM Wrote:150 ft lbs its the problem its the rust and the bolt seizing up.. I've rebuilt the front suspension on my cousins focus and those bolts wouldn't budge with out my impact.... but it was from 2000 and it had almost 200,000 km... you're right about corrosion. i had to use a breaker bar with a peice of pipe on the end for more leverage. i bet i can put out more torque than most impact guns. I rember there were these bolts at work that needed 1000ft.lbs. we had at least a 6 foot pipe on the torque wrench NikiterZTS, Jul 2 2008 Wrote:build a whole bunch....maybe you can sell em for $50 we'll see. I'm running out of time for this year (I'm going to be working out of the country for 6month) so I might not get it made till next year |
