I Have The Turbo Bug - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: I Have The Turbo Bug (/showthread.php?tid=17433) |
I Have The Turbo Bug - BerinG - 06-14-2004 Heard the flashers were ECU code locked.. so you could do cars with ame ecu code.. not sure about VIN.. but still.. dont think you 2 have the exact same code.. I Have The Turbo Bug - chumkila - 06-18-2004 So do you run the engines on standard compression ratio as bolt-on turbo applications or not? I Have The Turbo Bug - Paparoach - 06-19-2004 chumkila,Jun 18 2004, 08:44 AM Wrote:So do you run the engines on standard compression ratio as bolt-on turbo applications or not?You definately can run it on standard compression but very easily you can lower your compression by installing the head gasket from the Ford Escape. ;) I Have The Turbo Bug - darkpuppet - 06-19-2004 Paparoach,Jun 18 2004, 02:17 PM Wrote:You definately can run it on standard compression but very easily you can lower your compression by installing the head gasket from the Ford Escape. ;)Really? I Have The Turbo Bug - Paparoach - 06-19-2004 darkpuppet,Jun 18 2004, 10:21 AM Wrote:Really :DPaparoach,Jun 18 2004, 02:17 PM Wrote:You definately can run it on standard compression but very easily you can lower your compression by installing the head gasket from the Ford Escape. ;)Really? I Have The Turbo Bug - chumkila - 06-19-2004 Paparoach,Jun 18 2004, 02:17 PM Wrote:Obviously running it on standard c/r will be dependant on what power output you are pushing for.chumkila,Jun 18 2004, 08:44 AM Wrote:So do you run the engines on standard compression ratio as bolt-on turbo applications or not?You definately can run it on standard compression but very easily you can lower your compression by installing the head gasket from the Ford Escape. ;) Ford Escape? Sorry i've not heard of that as we don't have it in the UK. :D LOL. What c/r does this headgasktet lower to? Also why use this gasket? Is it multi-layer? I Have The Turbo Bug - Paparoach - 06-19-2004 The escape is an SUV....the gasket is thicker...so lowers compression. :D The exact numbers I am not sure of... I Have The Turbo Bug - chumkila - 06-19-2004 Just used Google to find one. ;) Are these Escape's all 2.3 ?? We use a Focus 2000 Zetec-E Multi-layer headgasket from Ford for most ZT applications. I Have The Turbo Bug - Paparoach - 06-19-2004 chumkila,Jun 18 2004, 10:39 AM Wrote:Just used Google to find one. ;)The old escape had the 2.0L engine...the new ones use the 2.3 duratec. I Have The Turbo Bug - chumkila - 06-19-2004 B) |
