Noises -what Else Is New! - Printable Version
+--- Thread: Noises -what Else Is New! (/showthread.php?tid=10258)
Noises -what Else Is New! - focusnme - 04-05-2006
ok ok - - yes yes - you have heard all the noises from a focus - now is time to test you expertise....
When i stop quick and/or accelerate quickly a thump from the fromt on the car happens but disapears as soon as i am driving
second - what is the best way to get a chopped tire smooth again - only 2500km on tires and i just got a re-alignment
third - does anyone know where the motor mounts are in my car - pics would be good (ztw wa-gen 2003)
and somethin else - damn forgot - ok start with these
thanks
craig
Noises -what Else Is New! - MAlby7 - 04-05-2006
oooo ooo I think I have number 1 also. I believe the answer is "what is the passenger's side motor mount?".
where is it? - question # 3 - ha ha
also - can it be tightened or does it need to be replaced?
Noises -what Else Is New! - mo_focus - 04-05-2006
its in your engine bay ;)
and it needs to be replaced. As for locating them there are two on top.
1- under your air filter. you must remove the box to see it
2- behind the engine close to the egine wall( am i right on this one?)
3-4 are under the car, but i can't remember where right now
Noises -what Else Is New! - hardk0re - 04-05-2006
Driver Side: Under the air box
Passenger side: Under the coolant resevoir
Rear Tranny Mount: Under the drivers Side at the very bottom of the engine.
Noises -what Else Is New! - focusnme - 04-06-2006
ok and the noises???????????
ok and the tires??????????????
Noises -what Else Is New! - hardk0re - 04-06-2006
The noises are the motormounts. (possibly)
The tires, buy new ones.
Noises -what Else Is New! - 2001 ZTS - 04-06-2006
Your #1 noise is likely a cracked spring like I had. The crack happend within the first turn of the coils and hidden by a short rubber sleeve. I cant tell you if it is the first turn from the top or the bottom because I didn't work on the replacement. There is a TSB for it if I remember right.
Noises -what Else Is New! - NOS2Go4Me - 04-07-2006
Tires are tires... get a new pair or new 4some.
Get your minds out of the gutters, animals :D
