Fan Blower Motor - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Fan Blower Motor (/showthread.php?tid=1050) |
Fan Blower Motor - Frost__2001 - 08-10-2009 hey guys I noticed that my interior fan only works on setting 4 now, it's very very reduced in power compaired to before, and dose nothing in the other 3 settings, could this be the fan blower motor or a faulty switch? Fan Blower Motor - Scorcher000 - 08-10-2009 Ussually a switch. But check the electrical coils on the Fans then selves. There shoudl be a shot on the bottum in between both fans where a little square object sticks out and the electrical elements should be there un covered. I found them when I had to take the front end apart do to a person without brake lights and a long trailer hitch. When I saw mine the car was only 2 years old then if not a little older and the electrical elements were already bad in the corossion department. But most likely the switch is at fault. Fan Blower Motor - Frost__2001 - 08-10-2009 well my car is a 2001, and I would not be suprised if it is the motor as the switch (dial) was replaced 3 years ago with the euro one. Fan Blower Motor - Focus man. Focus. - 08-10-2009 I would say either the fan or the resistor which controls the voltasge to the fan (controls the fan speed). Fan Blower Motor - ZX3_2NV - 08-11-2009 its that blue or white box in behind your glove box. I founf a post on FF and even on here before about it. I think it will take a $30 part from ford and a lil bit of sodering to fix it up. Fan Blower Motor - Frost__2001 - 08-11-2009 hmm i'll check that out later on thanks kevin & andrew Either or I have to do something else to the car at the same time so I'm not in a huge hurry to get it fixed until the weekend. Plus I found out a replacement motor is surprisingly cheap... if I have to replace it that is. Fan Blower Motor - Frost__2001 - 10-10-2009 So yeah I replaced the fan switch, and had the fan blower checked and I still don't have fan speeds 1-3 working in my car, any ideas guys? Fan Blower Motor - Focus man. Focus. - 10-10-2009 Sounds like the blower motor resistor. Like I said before. From my experience behind the parts counter that is what I would suggest. I wouldn't think it would be the switch. Fan Blower Motor - NoiSeeVT - 10-10-2009 Most likely the blower motor resistor I have replaced it my Focus (under warrenty and on the wifes sentra. Easy fix. David Fan Blower Motor - Feral - 10-10-2009 Its the Blower Motor Resistor pack you can find it behind the glovebox on the lower left side.. its got an electrical connector on it.. it will be either Blue White or Black |
