Fixing A Cracked Headlight? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Appearance (//www.focuscanada.net/forum/forumdisplay.php?fid=21) +--- Thread: Fixing A Cracked Headlight? (/showthread.php?tid=11074) |
Fixing A Cracked Headlight? - pavlako - 01-31-2006 Hey, Someone just recently backedup in the front left of my car which among other things managed to crack my HID headlamp :angry: . Well I'm just wondering if this can be fixed or if I basically need to buy a new light? It's the cover thats cracked (the glass/plastic whatever it is). Any help would be greatly appreciated. I tried to search but couldn't find what I was looking for. -Paul Fixing A Cracked Headlight? - nass - 01-31-2006 pavlako,Jan 30 2006, 06:18 PM Wrote:Hey, are you talking about the MACH HID? Hella aftermarket lights? if it's the MACH lights then I don't see why you couldn't get another cover and replace it it should all be the same size I think. If it's a Hella aftermarket light then you're out of luck and will have to buy a new projector pics would also help Fixing A Cracked Headlight? - pavlako - 01-31-2006 Sorry it is the MACH HID's, I'll post some pics up tonite. If it's the same plastic covers as my stock ones I'll just replace it with those, that would save me a lot of money! Fixing A Cracked Headlight? - nass - 01-31-2006 pavlako,Jan 30 2006, 06:58 PM Wrote:Sorry it is the MACH HID's, I'll post some pics up tonite. I've never seen one in person but I don't think they'd be that different and you might get very lucky if it's a direct fit. Taking off the cover isn't that hard either... just grab your moms/gf/sisters hairdryer, a butter knife/phillips screw driver or anything flat, some wood wedges or even card board. heat up the glue in small sections starting at the top middle. It doesn't take much to heat the glue up. Once the glue starts warming up put in your flat ended device and start to pry open. It's a lil hard at first but don't worry it'll spread open much like your date after a few tequilla shots. Once you have it spread apart stick in your wooden wedges/cardboard between both halves so they won't seal back up. Keep working your way to the edges using the same technique and by the time you have the top open the bottom should just loosen up on it's own. Don't force it too much though. good luck Fixing A Cracked Headlight? - SL8RZZX3 - 01-31-2006 I might be wrong, but i'm pretty sure that the Mach's are a glass lense and the stockers are plastic.... you might end up with alot of glare if you swap to a plastic lense Fixing A Cracked Headlight? - paolo - 01-31-2006 the machs are plastic, you can use the plastic lens from the factory halogen headlights, but if u jsut do one side, you will notice the pattern is a bit different where it meets your grille, so i suggest you do BOTH left + right, you might as well. Fixing A Cracked Headlight? - paolo - 01-31-2006 btw.. Pavlako, where the hell have u been? Fixing A Cracked Headlight? - pavlako - 01-31-2006 Well first of all thanks to everyone for the help. I'll take a look at my stockers and see if they match up. Second, Paolo as you can see by my name, I've been LURKING! haha I check up like once a week but mostly to read up but I know I never post. |
