Gauge Cluster Pod - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on I.C.E. (//www.focuscanada.net/forum/forumdisplay.php?fid=23) +--- Thread: Gauge Cluster Pod (/showthread.php?tid=11129) |
Gauge Cluster Pod - hardk0re - 01-25-2006 Well last year around this time I got inspired by a few members here posting that they made gauge pods/filled in the radio surround. Since then I made a ton of these things for guys here and some on FF. This may inspire someone else now :P Did these for a member on the site, theres nothing special about the radio surround, its just painted. I'll update this thread when his install is done since he's comming over and we'll install his gauge and the pieces. ![]() Gauge Cluster Pod - ANTHONYD - 01-25-2006 I've seen these in person....They're flawless! Gauge Cluster Pod - NOS2Go4Me - 01-26-2006 You're way too modest Kev... you've got some serious skills! Gauge Cluster Pod - ZTS_DJ - 01-27-2006 i wanna paint my radio surround, but i dont know what steps to use, my radio surround is like brushed aluminum Gauge Cluster Pod - hardk0re - 01-27-2006 I'm not an expert by any strech but this is what I did: - Wash the part thoroughly using dishsoap. - Sanded it with 800 grit - Cleaned the part again - Prime it and let dry - Wet Sand with 1000 grit Now here I used rim paint since I had a bunch left from some rims I was touching up, it worked well suprisingly. - Painted it and let dry (about 2 hours) - Clear coated it (3 coats) letting dry slightly between coats. Maybe with the brushed one you may require more sanding to get it smooth. Now to get the cigarette lighter out was easy theres two clips on the inside that hold the metal center in, push those out while pressing up on the bottom of the part and it should come loose. Once the center is out the rest comes out easy. |
