Neat Linked-file Bug, Possibly - Printable Version
+-- Forum: Support (//www.focuscanada.net/forum/forumdisplay.php?fid=6)
+--- Forum: Site Support/Updates (//www.focuscanada.net/forum/forumdisplay.php?fid=29)
+--- Thread: Neat Linked-file Bug, Possibly (/showthread.php?tid=11665)
Neat Linked-file Bug, Possibly - NOS2Go4Me - 12-09-2005
Hey Steve, can you duplicate this and let me know if it does it for you?
Host a simple PDF file... and then deep-link to it directly.
Can you download it via the link shown in the message post? I tried it earlier with 2 PDFs from home and it didn't work. Then, I put them both into one RAR file and presto... downloading works. It all stayed within the same source directory, etc.
I was getting 404s saying file not found, but the capitalization and formatting was right (all lowercase, single filename, no spaces, .pdf extension).
Thanks man!
Neat Linked-file Bug, Possibly - NOS2Go4Me - 12-13-2005
Oh, and the iono smiley - you can't see his arms hardly - :iono:
Neat Linked-file Bug, Possibly - darkpuppet - 12-13-2005
There's no reason for one set of links to work, and another to not work..
HTTP links are all the same ...
let's try a TTC map
yup, that works.. check your server settings.. or DNS if domain not found...
most likely a soft user interface error... just remove the faulty device inputing to the keyboard!
It very well could have been a PEBKAC error (Problem Exists Between Keyboard And Chair).
I'll check it again at lunch.
Testing - http://teamx.webhop.org/focusfiles/FocusedPC.pdf
OK, that works. Same directory as the ones that failed. WTF?
Wait, I figured it out. When I RARed the files on my PC, I had "show extensions for known file types" enabled. When I RARed it, it preserved the extensions. When I copied them over flat to the webserver, Win2K (with show extensions off) tacked on another ".pdf" to the filename.
Essentially, it was filename.pdf.pdf
Whoops. Not really my fault, but I should have noticed it. Nothing to see here, move along :ph34r:
