Funny Smell From Heater Vents - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Funny Smell From Heater Vents (/showthread.php?tid=11793) |
Funny Smell From Heater Vents - paolo - 11-29-2005 noticing a funny smell smells like burnt popcorn when the heat is high... anyone else have the same problem?? Funny Smell From Heater Vents - meford4u - 11-29-2005 Any liquid around the passenger floor? Funny Smell From Heater Vents - schade - 11-29-2005 kinda sounds like the heatercore ... can you smell antifreeze? Funny Smell From Heater Vents - paolo - 11-29-2005 i had a clutch cylinder leak a while back fixed under warranty, that was the only leak on the floor, i dont really remember what burning antifreeze smells like... maybe someone can take a whiff of my vent air and tell me? Funny Smell From Heater Vents - meford4u - 11-29-2005 burning antifreeze has a very pungent odour. Can it be described as burnt popcorn? Not so sure about that. Funny Smell From Heater Vents - NefCanuck - 11-29-2005 paolo,Nov 28 2005, 08:34 PM Wrote:i had a clutch cylinder leak a while back fixed under warranty, that was the only leak on the floor, i dont really remember what burning antifreeze smells like... maybe someone can take a whiff of my vent air and tell me? I kinda doubt you could forget that smell... Burning anti-freeze makes my eyes water :blink: NefCanuck Funny Smell From Heater Vents - focusnme - 11-29-2005 check your cabin air filter - maybe its green/black and mouldy?? i seen some pretty gross ones come out of my car Funny Smell From Heater Vents - 2001 ZTS - 11-29-2005 paolo,Nov 28 2005, 06:56 PM Wrote:noticing a funny smell smells like burnt popcorn when the heat is high... anyone else have the same problem?? Automatic? I've not experienced it myself but a toasted autobox is suppossed to have a "woody" smell. That is "woody" as in lumber, as in logs as in ............ah forget it, you can ask the guys in Saskatewan about what the other kind of woody smells like. ![]() Funny Smell From Heater Vents - paolo - 11-29-2005 my coolant level has been noticably low.. ive needed to top it off atleast 2 times now because it magically lowers itself?? BTW, I have a Stick, not an automatic.. I also had my cabin air filter replaced 2 times so far.. I doublt its that. Funny Smell From Heater Vents - 2001 ZTS - 11-29-2005 paolo,Nov 28 2005, 11:06 PM Wrote:my coolant level has been noticably low.. ive needed to top it off atleast 2 times now because it magically lowers itself?? BTW, I have a Stick, not an automatic.. I also had my cabin air filter replaced 2 times so far.. I doublt its that. I can't believe it but it smells like you have a cracked head or worse a bottom end job? Any discolourization in what is left of your rad fluid or oil dip stick look "milky" or "foamy"? (oil and coolant mixing) Funny Smell From Heater Vents - schade - 11-30-2005 ^^^^ what he said :( put some cardboard under it at night and see if you get anything on it after leaving it parked over night ... or you can always take it to a garage and have the cooling system pressure tested, and see if it holds pressure ... sure way to find a leak/crack head then. Funny Smell From Heater Vents - paolo - 11-30-2005 will xtended warranty cover this? Funny Smell From Heater Vents - OAC_Sparky - 11-30-2005 paolo,Nov 29 2005, 11:57 PM Wrote:will xtended warranty cover this?It should. Funny Smell From Heater Vents - ZTWsquared - 11-30-2005 2001 ZTS,Nov 29 2005, 12:14 AM Wrote:Any discolourization in what is left of your rad fluid or oil dip stick look "milky" or "foamy"? (oil and coolant mixing)[right][snapback]158201[/snapback][/right]Did you check the condition of your oil? You might also check your exhaust ... even the smallest amount of coolant going into the combustion chamber will produce a strong smell and perhaps even some white smoke. Funny Smell From Heater Vents - ANTHONYD - 12-01-2005 You may have a leak in the car. Funny Smell From Heater Vents - paolo - 12-01-2005 the car is going to be looked at by ford, but i have no idea why my exhaust would be the problem? Funny Smell From Heater Vents - ZTWsquared - 12-01-2005 paolo,Nov 30 2005, 08:31 PM Wrote:the car is going to be looked at by ford, but i have no idea why my exhaust would be the problem?Check exhaust = diagnostic check. Check the smell of your exhaust gases for evidence of coolant leaking into the combustion chamber -- blown gasket or cracked block might explain the loss of coolant; especially if you find none on the ground or in the oil. |
