Odometer Trick? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Odometer Trick? (/showthread.php?tid=12089) |
Odometer Trick? - FociPhil - 11-09-2005 What do you do for the odometer trick? I used to do it all the time but i forgot... i took out my speed-hut gauges and need to reset everything. Odometer Trick? - NOS2Go4Me - 11-09-2005 with key off, hold down trip odo reset. Start car. Keep holding till trip odo flashes... cycle through by pushing the reset as needed... tach is 8 presses, etc. resets when you turn the car off. Odometer Trick? - dBlast - 11-09-2005 What is the purpose of this? or can you explain it further? I remember a few years back I was stuck in traffic and this guy in a modded black ZX3 next to me was trying to explain this odometer trick to me but the light changed and I did not get what the purpose of this was. Thanks. Odometer Trick? - Flofocus - 11-09-2005 You can pull pass codes, change your Digital display to read KM/hr or Miles/hr instead of your Gas tank trip or whatever its called. I found it handy to give the exact idle to Tom for fine tuning. Thats another thing it will give you the exact RPM, something good if you've fawked up installing your guages and need to know if theyre set right..... Odometer Trick? - FociPhil - 11-09-2005 taking off my gauges the rpm needle came off, so i just want to reset everything and make sure it reads right. Thanks NOS/Flo Odometer Trick? - Raine - 11-09-2005 So how do you cycle thru them. It'd be cool to have it read km/h as opposed to the milage since last fill Odometer Trick? - schade - 11-09-2005 just keep pushing the reset button and it'll scroll through all of them ... Odometer Trick? - Flofocus - 11-11-2005 Yeah, obvisouly, it will read 0.00, but make sur eyou select the right one.....you can have both Miles and Km's/hr on it, and the selection is right after another so you may have to drive around to figure out which one your on..... Odometer Trick? - microbunny - 11-11-2005 So what are all the different readings? KMH, MPH, RPM......thats it?! Odometer Trick? - NOS2Go4Me - 11-11-2005 The rest are DTC codes and other settings... I think one is voltage, another coolant temperature. Don't quote me, it's been months. Odometer Trick? - Flofocus - 11-11-2005 microbunny,Nov 10 2005, 04:33 PM Wrote:So what are all the different readings? KMH, MPH, RPM......thats it?! here you go bunny boy http://www.focushacks.com/index.php?modid=13 Odometer Trick? - microbunny - 11-12-2005 Ahh thank you sir! |
