Good Lubricant For Suspension Bushings? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Off Topic (//www.focuscanada.net/forum/forumdisplay.php?fid=16) +--- Thread: Good Lubricant For Suspension Bushings? (/showthread.php?tid=12770) |
Good Lubricant For Suspension Bushings? - Kool_ZX3 - 09-28-2005 Title says it, what's a good lube for bushings? Good Lubricant For Suspension Bushings? - paolo - 09-28-2005 Hmm, I'll take a stab in the dark... WD-40 perhaps? Good Lubricant For Suspension Bushings? - 2001 ZTS - 09-28-2005 Maybe it's not your bushing. One of my front springs was cracked near the bushing, on the first turn of the coil. Good Lubricant For Suspension Bushings? - Kool_ZX3 - 09-28-2005 not a broken spring, just squeaky bushings Good Lubricant For Suspension Bushings? - DadsToy - 09-30-2005 Kool_ZX3,Sep 27 2005, 09:10 PM Wrote:Title says it, what's a good lube for bushings? Well, my Energy grease-fitting sway bar bushings say to use "your favourite grease" or something like that. Prothane provides some special teflon-based grease that is really sticky and thick. I added grease fittings to all my rear suspension bushings and use lithium grease and, to date, seems to work OK. Any help? :blink: Good Lubricant For Suspension Bushings? - tdot-zx3 - 09-30-2005 That generic black grease you can find at almost all mechanics places works fine... I used that on my old car lots of time. Good Lubricant For Suspension Bushings? - ZX3TUNING - 10-02-2005 using oil-based grease will destroy your bushings!!! don't use Moly grease or wheel bearing grease or axel grease! you need something called "Sil-Glide." it's a silicone based lube designed for rubber and a plastics like urathane. it wont damage the bushings or rubbers and is resistant to wash off from water. i use this on every car i work on that has a squeak and the problems always get fixed. it comes in a white tube and you should be able to find it at most decent Automotive stores like Lordco or any brake specific shop. Good Lubricant For Suspension Bushings? - Kool_ZX3 - 10-02-2005 ZX3TUNING,Oct 1 2005, 04:01 PM Wrote:using oil-based grease will destroy your bushings!!! don't use Moly grease or wheel bearing grease or axel grease! I used some crc extreme siliscone lubircant, seems to work good B) Good Lubricant For Suspension Bushings? - ANTHONYD - 10-03-2005 Lithium won't work? Good Lubricant For Suspension Bushings? - NefCanuck - 10-03-2005 ANTHONYD,Oct 2 2005, 12:15 PM Wrote:Lithium won't work? Don't think so, in fact that's what I use on the gears and pistons on my knee brace to keep it moving smoothly :ph34r: NefCanuck |
