How Hard Is It To Install Exhaust - Printable Version
+--- Thread: How Hard Is It To Install Exhaust (/showthread.php?tid=12852)
How Hard Is It To Install Exhaust - smith21 - 09-23-2005
ok, well, i'm sitting here, wondering when my exhaust is gonna be coming in, and hoping that i can have it for this sunday's cruise night. But what i was wondering, if it comes in tommoro, and most shops are closed weekend, would i be able to put this in myself? Is it really that hard?
How Hard Is It To Install Exhaust - scoobasteve - 09-23-2005
easy, just have an angle grinder handy to make the cut... then its 2 bolts and some hangers to remove it... install is easier than removal
ive done it in half an hour...
1hr if youre gonna use a hacksaw.
How Hard Is It To Install Exhaust - habmann - 09-23-2005
I did mine last year, the only thing i would say that might be a problem is getting the front bolts off. Mine were totally seized, had to get them cut off, now if you've got a grinder or torch it shouldn't be much of a problem.
How Hard Is It To Install Exhaust - Focus Is Art - 09-23-2005
Cut the fvcker off will be your biggest problem
How Hard Is It To Install Exhaust - FociBC - 09-23-2005
its easy..... I did mine back when I had my sedan. Loved the sound of the MBRP on that car
Use the force or this link whichever helps you the most :P
How Hard Is It To Install Exhaust - Oscar The Grouch - 09-23-2005
A Dremel are your friend. :P
Probably could cut it in 5 min and go through 2 disks. You could also use a skill saw with a metal cutting blade.
How Hard Is It To Install Exhaust - FociPhil - 09-24-2005
Yeah my bolts were totally seized to, have to cut them off, otherwards its pretty easy
How Hard Is It To Install Exhaust - scoobasteve - 09-24-2005
I didnt have to cut mine, but the car did have 5000km when i did my exhaust
How Hard Is It To Install Exhaust - paolo - 09-24-2005
Its SOO easy to install an exhaust I can do it with my eyes closed and no experience, just raise the car a bit... seperate the rear resonator and muffler and cut-inbetween, unbolt/unhock everything, bolt up the new one piece by piece, install new exhaust hangers if necessary, and your done. I actually didnt install it myself though, even though I know its easy.
How Hard Is It To Install Exhaust - FociBC - 09-24-2005
Oscar The Grouch,Sep 23 2005, 05:37 AM Wrote:A Dremel are your friend.  :P
[right][snapback]144154[/snapback][/right]
A bloody dremel man don't be foo. Use a sawzall.
How Hard Is It To Install Exhaust - ZX3TUNR - 09-24-2005
6 bolts
any small grinder will work. buy a blade from cdn tire. Your set! I even seen some ppl cut there stock exahust off with dremels lol Takes a bit longer but what ever works.
I took mine off with a hack saw at a gas station.
How Hard Is It To Install Exhaust - 02ztsian - 09-25-2005
I used a hacksaw, took 30 min to cut it off, then another 30 to remove the old exhaust. Word of advice, after you jack it up on jackstands hose down the front bolts with Liquid Wrench or WD-40 then do the rubber hangers as well. This will give it some time to work while you are cutting the exhaust. Big old prybar to pry off the rubber hangers. A case of beer at the standby. And, finally, do this late at night so when you test fire it you piss off your neighbours!
How Hard Is It To Install Exhaust - smith21 - 09-26-2005
Well guys, i attempted it, with no luck, those damn bolts right after the flex are KILLING ME! They are seized on really good, and i tried getting ahold of a few garages to see if they can cut them off, but it's sunday, and all the lazy bastards are probably sitting on their ass having a cold beer! Anywyas, i'm booking an apointment at my muffler shop and gonna get them to do it either 2morro or tuesday. Thanks for the help tho guys
How Hard Is It To Install Exhaust - FociBC - 09-26-2005
I used my angle grinder to cut off those bolts believe or not. They were are real pain in my ass
