Brakes-squeek - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Brakes-squeek (/showthread.php?tid=13) |
Brakes-squeek - patrick23 - 04-28-2010 got a question guys. I just have new pads, shoes and ss braided lines I got from brake gb installed. now my brake squeek on low pedal pressure low speed aplication only, not when firm pedal pressure is applied. It's kinda annoying, but I figure w/ street/track compound it bounds to happen. so, is Hawk HPS supposed to squeek on low operating temp? like my low speed low pedal pressure application ie like at the mall lot, on rush hour jam, etc if not I would get the shop that put it in have a look at it. Brakes-squeek - Oscar The Grouch - 04-28-2010 There is some lubricant that comes with the pads you should have put on. I get the same squeak too, not worried about it. Brakes-squeek - konafocuswrc - 04-28-2010 looks like all hps pads are noisy.. mine is hps as well and it squeals like a pig.. Brakes-squeek - sonic_mikey - 04-28-2010 patrick23,Apr 27 2010, 02:38 PM Wrote:got a question guys. I just have new pads, shoes and ss braided lines I got from brake gb installed. now my brake squeek on low pedal pressure low speed aplication only, not when firm pedal pressure is applied. It's kinda annoying, but I figure w/ street/track compound it bounds to happen. I have the same pads with EBC slotted and dimpled rotors and some noise will come from them during light application. FYI, the compound is rated the same @ start-up and operating temp (FF rating) so they have the same COF regardless of temp. Also, the lil pouch of red goop is a type of adhesive that should go on the back of the pads to bond them tight to the caliper. Brakes-squeek - OAC_Sparky - 04-28-2010 sonic_mikey,Apr 27 2010, 05:16 PM Wrote:Also, the lil pouch of red goop is a type of adhesive that should go on the back of the pads to bond them tight to the caliper.Yes, a lot of people mistake that for lubricant. Brakes-squeek - Flofocus - 04-29-2010 Hawk pads? Very Normal for them to squeal. Especially annoying when backing up! Brakes-squeek - patrick23 - 04-29-2010 OK, thanks guys for the infos. Brakes-squeek - fatphocus - 04-29-2010 Yupp, even my CSVT has Hawk racing pads and they squeal coming to a stop...like 20km only and lower it squeals..annoying but I learned to deal with it by turning the radio up more lol Brakes-squeek - konafocuswrc - 05-02-2010 i had ebc green with powerslot slotted before and stopping power wasn't good (when i was in san francisco), i had to hit curb to stop..it was only 5 block downhill driving..and lots of brake dust built up.. then had brembo oe pads and brembo oe rotors, liked the stopping power.. then i am now have hawk hp+ with brembo oe rotors and all i hear is annoying squeal and stopping power is okay.. best combo i had so far was brembo oe pads and brembo oe rotors.. RE: Brakes-squeek - zx5power - 05-17-2010 one way to help a squeal is to remove pads and sand down the sharp edges , dealer pads come rounded off cheaper ones do not , just an idea , also bg sells stop squeal seems to work ok RE: Brakes-squeek - Flofocus - 05-18-2010 stop squeal doesnt work on hawk. ask me how I know... lol |
