Side Skirts? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Appearance (//www.focuscanada.net/forum/forumdisplay.php?fid=21) +--- Thread: Side Skirts? (/showthread.php?tid=13233) |
Side Skirts? - focusonthis88 - 09-04-2005 How to you install side skirt? Do you put 2 way tape or uretane? What did you guys use? Side Skirts? - skifreak69 - 09-04-2005 I've heard the adhesive for windshields works well. Two sided tape usually fails in the long run. Side Skirts? - focusonthis88 - 09-04-2005 Does somebody know? Side Skirts? - ZX3TUNING - 09-05-2005 windshield adhesive is what we always use and it works better than anything we have found yet. most quality body shops that do a lot of work with aftermarket body kits will say and use the same thing. if you are going to do it yourself, get the helping hand of a good friend because that stuff can murder your paint if you mess up and get it where it shouldn't be! Side Skirts? - focusonthis88 - 09-05-2005 Thx, Mitch Side Skirts? - ZX3TUNING - 09-05-2005 if you do get it where it shouldn't be, i have found Gasoline takes it of fairly well but you need to wash the car instantly to get the gas off before it hurts your paint and so the glue will bond! ;) Side Skirts? - focusonthis88 - 09-15-2005 Would 3m 2-way tape work for sticking does skirts? Side Skirts? - ZX3TUNING - 09-15-2005 it does but it doesn't work for long. bump the skirts or drag your foot getting out and you can pull the skirt away from the body. Side Skirts? - guilty - 09-15-2005 Especially in the cold, if you get extreme cold weather the tape wont hold very well. Side Skirts? - focuzedn2o - 09-22-2005 where do u get this adhesive? Side Skirts? - ZX3TUNING - 09-22-2005 anywhere that does auto-glass repair should carry it. |
