Modded Chips (not The Humpty Dumpty Type Either) - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Modded Chips (not The Humpty Dumpty Type Either) (/showthread.php?tid=13586) |
Modded Chips (not The Humpty Dumpty Type Either) - Slimsride - 08-17-2005 Can someone please explain what the hell "changing the chip" in a vehicle means. Okay, i'm a bit of a retard and new to the Ford Family, so i figured i would get as many dumb questions outta the way now. I wanna do some stuff to the car, obviously and wanna do it right the first time, instead of making the expensive mistakes. I mean i do plan on winning the lottery eventually, but until then, i have to keep mistakes to a minimum. K, going back to the "chip"...is this a hard job, big job, easy? what what what...someone tell me... :( :( :( :( Modded Chips (not The Humpty Dumpty Type Either) - mo_focus - 08-17-2005 Ok, well i have a chip in my glovebox and its been there since last year, When the gas prices started climbing. The most important question you have to ask yourself is why do you need a chip? unless you have done major mods( turbo/supercharger) i dont think its really worth it. Considering you have to put high octane gas once you have got the chip. it becomes very costly. is it easy to change? yeah sure. pretty easy ( well atleast my superchip) was. take the comp module out and sand off the end and slap on the new one. I know there were how to do's while back here. Do a search and i'm sure you can find it. You might also want to get a chip if you are planning on removing you speedlimiter. In some cases( me) it didnt work. Limiter stayed. So that was useless, hence why the chip is in my glovebox rather then on the comp module. Best of luck Mo Modded Chips (not The Humpty Dumpty Type Either) - nass - 08-19-2005 mo_focus,Aug 16 2005, 05:37 PM Wrote:Ok, well i have a chip in my glovebox and its been there since last year, When the gas prices started climbing. The most important question you have to ask yourself is why do you need a chip? unless you have done major mods( turbo/supercharger) i dont think its really worth it. Considering you have to put high octane gas once you have got the chip. it becomes very costly. I don't think that every program you get forces you to run higher octane? it depends on the program you are running I think. Eventually I will get a chip mainly to turn off the emissions. wanna sell PM me :) Modded Chips (not The Humpty Dumpty Type Either) - ZX3TUNR - 08-19-2005 My opninion is just get the Xcal2 flasher for $450. Dont have to mess around with the ecu or any chips. Can go back and forth between tune and stock plus you get a OBD2 reader and datalogger. Modded Chips (not The Humpty Dumpty Type Either) - Slimsride - 08-19-2005 ZX3TUNR,Aug 18 2005, 10:11 AM Wrote:My opninion is just get the Xcal2 flasher for $450. Dont have to mess around with the ecu or any chips. Can go back and forth between tune and stock plus you get a OBD2 reader and datalogger. Are this things (Xcal2) hard to use? do you need to be a rocket scientist to understand what your doing?? Modded Chips (not The Humpty Dumpty Type Either) - ZX3TUNR - 08-19-2005 no. there easier then the chip you plug it into obd port, xcal turns on, bring you to a menu and ask what you want to do, click custom tune, then it shows the loaded tunes and ask what one, choose the tune press select, message comes up and tell you to put key in on position and press select, wait a minute to load, xcal2 says whens its done, turn key off and unplug. its super easy. pushing the clutch in and out is harder work. Modded Chips (not The Humpty Dumpty Type Either) - Slimsride - 08-19-2005 awesome...hmm, where can i pick this little magic box up?? Modded Chips (not The Humpty Dumpty Type Either) - ZX3TUNR - 08-19-2005 Mitch aka Zx3tuning.com You get 3 tunes with it also with a bunch of goodies/options to choose from. Im sure Mitch can help you out decide what options to pic. |
