12 Volt Rig - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: 12 Volt Rig (/showthread.php?tid=13774) |
12 Volt Rig - Slimsride - 08-07-2005 Okay, i'm going to try and explain something, without getting myself lost. I want to build a 12 volt rig, where i can attach addon's without having to spice and chop all my "power" wires. you know have one power point in which to hook up things like neon lights, etc. Has anyone done this yet? 12 Volt Rig - SVT dean - 08-07-2005 ya i will try to get a photo of it 12 Volt Rig - Slimsride - 08-07-2005 sweet, was it difficult to build? where did you put the "inital" hook up. 12 Volt Rig - SVT dean - 08-07-2005 ![]() ![]() ![]() ![]() ![]() 12 Volt Rig - SVT dean - 08-07-2005 just planning and time 12 Volt Rig - Slimsride - 08-07-2005 Dude, that's like SICK...hahah. Awesome though. I am curious though, do you have ONE initial wire powering this off the battery? 12 Volt Rig - SVT dean - 08-07-2005 ya on the top pic you see the power distro with the fuses well that running off the relay beside it and the relay is ran off of the ignition and the poer is coming striaght off the batt so no power untill the ignition is turned on and everything is fused the top pic is just for my guages the other pics are of my main disconnect from the batt all the power wires are for starter alt. main fuse box and secondary fuse box line then one for my inverter and one for my guages 12 Volt Rig - Slimsride - 08-07-2005 well i dont' need somethign so elbarote, but it gives me an idea..thanks much apprciated 12 Volt Rig - SVT dean - 08-07-2005 just what ever you do add a relay to what ever wire you take from the car be it ignition amp turn on or what ever just AD A RELAY or you cook wires 12 Volt Rig - Slimsride - 08-07-2005 any specific kind? or is it all pretty generalized??? sorry, i know something about wiring, but i could always use a bit of a heads up 12 Volt Rig - SVT dean - 08-07-2005 bosch 30 amp 5 pin relay with 86 trigger in 87 12 volt consent 85 ground 30 out put (trigger out) 12 Volt Rig - Slimsride - 08-07-2005 excellent..i have one of those...which i had to buy for my underglow kit....sweet, one less thing to buy. mind you i'm not sure if i'm gonna put my kit on this car....yet |
