Sound System - Printable Version
+--- Thread: Sound System (/showthread.php?tid=13862)
Sound System - BradfordZX3 - 08-03-2005
I just bought a pair of MTX audio 5X7 spaeakers for the back of my focus and I was wondering about wirirng. I have a white with purple wire and a grey with white wire, does anyone know which is + and which is -. thanks guys
Sound System - Flofocus - 08-03-2005
It should say it on the Speaker terminals, shouldnt it?
these are the factory wires in the car.
Sound System - Mason - 08-03-2005
Do you have a Volt tester. Ats the only way you will find out.
Other then just trying it both way's. One way will sound proper and the other will sound like s**t.
i have a meter i will go check now. never thought of that
thanks
BradfordZX3,Aug 2 2005, 01:59 PM Wrote:i have a meter i will go check now. never thought of that
thanks
[right][snapback]127171[/snapback][/right]
No prob.
Sound System - focusonthis88 - 08-03-2005
If the volt tester doesn't work...get a 9 volt battery and put the wires on it. if the speaker go put the wire that is on the + on the battery is the +.
Sound System - scoobasteve - 08-03-2005
focusonthis_88,Aug 2 2005, 06:30 PM Wrote:If the volt tester doesn't work...get a 9 volt battery and put the wires on it.  if the speaker go put the wire that is on the + on the battery is the +.
[right][snapback]127256[/snapback][/right]
He's trying to figure out which factory wire is positive or negative.
ah...I didn't read it correctly. sorry. :ph34r:
HAHA but If I rember right from my ford wiring hell when I installed my door speakers. Then purple is positive... Not 100% though.
Sound System - microbunny - 08-03-2005
purple is positive in my car!!
