Where Does This Sensor Go? - Printable Version
+--- Thread: Where Does This Sensor Go? (/showthread.php?tid=14189)
Where Does This Sensor Go? - Burnin21 - 07-14-2005
Hi guys,
I just put in my new 2000 Ported intake Manifold and I got everything set to go except this one sensor. Does anyone have any clue where it goes? I've looked for 2 hrs and I cant find nuthin. My CEL light is on too so I hope it goes away after I find out where it goes.
[Image: my.php?image=sensor8bc.jpg]
Where Does This Sensor Go? - schade - 07-14-2005
pic doesn't work
Hi guys,
[Image: sensor9lp.jpg]
sorry I posted in another thread, sorry for the screw up.
Heres the pic anyways
http://img28.imageshack.us/img28/5733/sensor9lp.jpg
Anybody? It runs right down between the intake tubes and splits off into two sensors, one being the Knock sensor I believe (its plugged into the block) and the other that I havnt been able to locate.
Where Does This Sensor Go? - hardk0re - 07-14-2005
dpfe?
Where Does This Sensor Go? - ZX3 Canuck - 07-14-2005
Over by the cam gears, at the back by the alternator would be my guess.
Where Does This Sensor Go? - ZX3TUNING - 07-14-2005
if i was to guess....
it's the fuel rail pressure, Cylinder head temp or the knock sensor harness.
all should be around that side of the head. the CHT sensor is a little brass fitting in the head with a 4" long wire and plug hanging off it.
but it looks like the fuel rail pressure harness, should be located on the cam gear side if the rail under the rail facing the back of the car.
Where Does This Sensor Go? - meford4u - 07-14-2005
The boy said because that is only one wire, it could be one of three things. Temperature, which he doubts, knock sensor that is located at the back of the engine, or check the alternator as it has a plug similar to that. Check near the bottom of the alternator. He said that the CEL might not disappear once you find the connection and you may have to have the code cleared.
Oh, and what happened to boost?
thinking about it yeah, theres a plug right by the alternator, its starting to look familiar.
Meford,
Boost is on its way my friend, I look at that friendly turbocharger everyday but I'm still saving money for some gizmos I'd like to put on before boost. I figure when I hit boost i'm hitting it big. Oh, I found where it was disconnected thanks alot for all the help guys! When my ride is finally something special to look at (under the hood) I'll bring it around so you all can take a glance or two. Thanks again!
Matt :)
Comming to the dyno day?
where was it disconnected?
i know it's not the ALT because that comes off the firewall and would not set of the CEL...
Where Does This Sensor Go? - Crazirich - 07-15-2005
is your car auto or manual?
it looks like a 2 prong plug to me, that could be tps, or injector, or other sensors, its a very popular plug
Where Does This Sensor Go? - Burnin21 - 07-15-2005
My car is a 5spd, and I managed to find where it was, its the oil pressure sending unit plug (from what i'm told) thanks alot for the help, couldnt have done it without you guys. :)
