Paint Problems - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Paint Problems (/showthread.php?tid=149) |
Paint Problems - razorskub - 03-28-2010 Hey, hope this is in the right place... I have a rust spot on my hatch door that I wanted to fix, but i can't find a paint that matches the code. the sticker inside the drivers door wasn't there when I bought it so I can't get the code from there but I'm pretty sure based on what I've researched it is Zinc Yellow B7. however I can't find anything like that at canadian tire or on the duplicolor website either. The only thing I found that was the same colour as my car ( i took a paint chip in and compared) was some engine enamel/ high heat stuff, would that be okay to use on the outside? if not where can I get the right colour paint? thanks. Paint Problems - Focus man. Focus. - 03-28-2010 Go to an automotive paint supply house and they can most likely custom mix you up a spray bomb in your colour. I know that it can be done here in Toronto. Paint Problems - SL8RZZX3 - 03-28-2010 Napa should be able to mix it up for youin either spray bomb or touch up and you have like 4 of them in the Winterpeg area Paint Problems - razorskub - 03-28-2010 right on, the spot is about 2 inches in diameter so i guess a spray? |
