Anyone Have An Obd Ii Scanner? - Printable Version
+--- Thread: Anyone Have An Obd Ii Scanner? (/showthread.php?tid=14929)
Anyone Have An Obd Ii Scanner? - Blackzx3 - 05-26-2005
Does anyone have a scanner that I could borrow.
The focus is shot, and not sure what is up with it, trying to figure things out before I have to give in and tow it to ford. Btw I'm in thornhill/markham.
Anyone Have An Obd Ii Scanner? - dBlast - 05-26-2005
I have a OBD II reader. I work in Thornhill. I can bring it tomorrow.
dBlast,May 25 2005, 05:17 PM Wrote:I have a OBD II reader.  I work in Thornhill.  I can bring it tomorrow.
[right][snapback]110796[/snapback][/right]
Serious that would be amazing. Should I come by your work on green lane. I'm just off of willowbrook 1st left north of green lane.
Come in and ask for Vince. I'll go over and read the code. It takes 30 seconds.
Anyone Have An Obd Ii Scanner? - darkpuppet - 05-26-2005
I can help out as well.. including all extended ford sensors... and you're not THAT far aways.
Anyone Have An Obd Ii Scanner? - dBlast - 05-27-2005
Here is a more detailed description of your code:
Quote:P0320 - Ignition Engine Speed Input Circuit Malfunction The ignition engine speed sensor input signal to PCM is continuously monitored. The test fails when the signal indicates that two successive erratic profile ignition pickup (PIP) pulses have occurred. Loose wires/connectors.
Arcing secondary ignition components (coil, wires and plugs)
On board transmitter (2-way radio)
The DTC indicates that two successive erratic PIP pulses occurred.
Anyone Have An Obd Ii Scanner? - Jays2000ZX3 - 05-27-2005
That would definetly cause some issues.
