Installing Intake - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Installing Intake (/showthread.php?tid=15158) |
Installing Intake - smith21 - 05-04-2005 ok guys, i picked up my intake today. I read over the instructions from the .pdf files, for the shorty intake by AEM, but mine is a bombs, is there a diff, and do i have to disconnect the battery for 20 mins? also, the bracket that holds the intake up, so it's not smashing against anything..i'm missing that, is there a way i can make/buy it somewhere? and where do i connect it to..thanks for the help guys, i'm just really lost and wanna get this put on SOON! Installing Intake - 01-yellow-ZX3 - 05-04-2005 Disconnecting the battery is always a good idea. Bracket might not be needed, but a piece of bar can be fabbed up easily on your own. Installing Intake - NOS2Go4Me - 05-04-2005 Disconnecting the battery is a great idea as it allows the ECU to see the greater airflow and adjust the air/fuel map accordingly. I re-did mine yesterday because of the car audio work, and it made a world of difference (hadn't been really done since I got the cone). As for the bracket, try reversing it and then tapping into the black steel bracket that runs behind the battery / battery box. That's actually where I mounted my inline fuse for my amp :) Just realized you don't have one... hmm. Take some aluminum, cut so that there's a hole in it just larger than the size of the tubing. Measure around in such a way that it makes an "arm" or bracket for the intake. This will be a bit of work, so tin might work as a stop-gap solution being cheap and tough (and hopefully not too ugly) in the meantime till you can fab something a little more durable and "bling" :D Hit me up on MSN, I'll fire you off a few sketched ideas I've done for mine :) Installing Intake - smith21 - 05-05-2005 i was looking at the bombs kits from e-bay, and it looked like there was an L-bracket and just a long piece of metal with 2 or 3 holes in it (at school, can't look at the exact picture) but my question is, where do i connect all of this? I'm lost! but oh well, i'll figure it out, or fab something of my own. But some help would be nice :D |
