Removing The Air Intake Box? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Removing The Air Intake Box? (/showthread.php?tid=15183) |
Removing The Air Intake Box? - focusonthis88 - 05-03-2005 How to you get the intake box off?? Removing The Air Intake Box? - BerinG - 05-03-2005 you pull on it.. its just like rubber clips that hold it.. of course you need to make sure your maf is unplugged, either maf out of the airbox or untighten the TB clamp before doing so.. but if you have the air box by itself with nothing connected on it, you should be able to pull on it.. you have that pipe under though that you need to pull out too.. Removing The Air Intake Box? - focusonthis88 - 05-03-2005 BerinG,May 2 2005, 11:41 AM Wrote:you pull on it.. its just like rubber clips that hold it.. Alright, I'll try that....Do someone know how to installed to Bomz Air Intake?? Removing The Air Intake Box? - NOS2Go4Me - 05-03-2005 I found pulling mine was a serious bitch... nothing was bolted on, but it was DAMN STIFF. Might want to consider vice grips and some rags to preserve the box for later (as you're yanking) or maybe some foam??? Removing The Air Intake Box? - focusonthis88 - 05-03-2005 Just finish installing the intake. Thx for the help guys, |
