New Stereo Idea - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on I.C.E. (//www.focuscanada.net/forum/forumdisplay.php?fid=23) +--- Thread: New Stereo Idea (/showthread.php?tid=15374) |
New Stereo Idea - ThraxXx - 04-17-2005 So I was looking at some new sub ideas when I crawled across this bad boy from MTX http://www.mtxaudio.com/caraudio/products/.../jackHammer.cfm Its insane...won't be happenin...thought you guys would get a real kick outta this earth quake causing heavy weight New Stereo Idea - FocusGuy7476 - 04-17-2005 wow 6000 W RMS New Stereo Idea - Honkeytonk Monkey - 04-17-2005 Yawn... New Stereo Idea - 2001 ZTS - 04-17-2005 320lbs? Just what every performance car needs! I know nothing about and could care less about ICE but you have to wonder how a speaker magnet that size impact on other things. New Stereo Idea - microbunny - 04-17-2005 Thats just friggin stupid.... :huh: New Stereo Idea - ThraxXx - 04-17-2005 Seriously..I have no clue how you could even consider powering that monster. My friend has an amp that is 3500watts maxpower 1500watts RMS @ 12V and well thats the biggest amp I have ever seen. I am sure MTX probably builds a surfboard amp to power it but DAMN!!! that thing is retardedly big. That sub would be perfect for maybe a wall based install in a mini van...with its 22" diameter... New Stereo Idea - GlennH - 04-17-2005 i think ya need to strap a few amps together... hehe imagine the sub box? HOLY !!!! New Stereo Idea - NOS2Go4Me - 04-17-2005 I never thought I'd ever use the word "stupid" to describe a piece of car audio in an ambiguous way, but I am. It's "stupid"-powerful, but also "stupid" in execution. I really don't know what to make of it. :blink: New Stereo Idea - Raine - 04-17-2005 ThraxXx,Apr 16 2005, 08:44 PM Wrote:That sub would be perfect for maybe a wall based install in a mini van...with its 22" diameter... What van wall do you know that would accept a 23" mounting depth and can accept a 320 lb weight? New Stereo Idea - NoiSeeVT - 04-17-2005 Theres the amp to power that if you have lots of $$$$$$$ TITANIUM ELITE MPH10K ---------------------------------- ⢠152 TO3PBL output transistors to cope with the massive output stage capability. ⢠It uses 96 TO247 MosFets in the power supply. ⢠4 separate Full Bridge DC-DC converters present. Two for the positive voltage high current supply and two for negative high current supply. Providing fully regulated DC rails for optimum performance under any load. ⢠Fifth DC-DC converter supplies required voltages for the low level input circuits and high voltgae low cuurnet supply for the voltage gain stages in the power amp. ⢠True instrumentation differential input stage using Burr Brown op amps. ⢠True Class A voltage gain and PreDrive circuitry. ⢠Level control implemented throught the use of 12 Bit multiplying DAC's that are controlled by the onboard DSP chip. Resulting in virtually zero gain error between channels. ⢠On board TI DSP controller. All amplifier operational parameters are monitored for correct operation. Output voltages and currents are measured cycle by cycle. Thermal measurements are implemented by using Analog devices digital temperature sensors accurate to within 1 degree - measured every few seconds. DSP controlled gain function allows accurate channel balance and if desired can implement "soft clipping" function or compression. Gain modualtion can occur at a rate of 40KHz. ⢠Forced air cooling is digitally controlled by the DSP controller, fans can be turned on/off at will depending upon operating conditions. ⢠Massive Aluminum chassis with hinged top cover coupled to hydraulic lift arms. ⢠Digital display allow control of various functions as well as displaying operating data. 1250W x 4 (4 ohm) 2500W x 4 (2 ohm) David New Stereo Idea - ThraxXx - 04-17-2005 Ok so two of those bad boys will barely hit the RMS Requirements of this sub...thats if they are running at 2ohm. nah this sub is too extreme for any car audio setup...if someone were to buy this it would be for bragging rights only. Also if someone were to buy this and 2 of these amps then they would be investing in 20 yellow top batteries just to maintain a constant load to run the massive bastard. NoiSeeVT,Apr 16 2005, 11:32 PM Wrote: New Stereo Idea - NoiSeeVT - 04-17-2005 Here than try this one Power Output: 2600 Watts RMS x 2 channels at 4 ohms and ≤ 1%THD+N 8110 Watts RMS x 1 channel at 4 ohms, 14.4V supply and ≤ 1%THD+N 7400 Watts RMS x 1 channel at 1 ohm, 14.4V supply and ≤ 1%THD+N New Stereo Idea - microbunny - 04-17-2005 That Is HorseShit ^^^^^ This thread is just useless,.....the sub is stupid, unuseable, and even for bragging rights..i'd say your still a fukin homo if you put the massive paper wieght in your car.... My word....what a waste /// New Stereo Idea - MAlby7 - 04-18-2005 That thing is so heavy and retarded that it would probably kill you. It probably uses the interior of your car as an enclosure. The magnetic field that it generates would give you a tumor! New Stereo Idea - dmcisaac - 04-18-2005 ...wee drive fords!...that sub will either kill the suspesion or everything else...remeber fords! New Stereo Idea - Penwraith - 04-26-2005 Wall Mount a 350 pound Sub ? . . . "aaah- Hmmmmmmmm" :rofl: :banger: A little particle board and constrution adhesive and Presto! :lol: :D A loose jackhammer! :blink: New Stereo Idea - ANTHONYD - 04-26-2005 Even if you could power it, it would justy bust loose and blow through the side of your car. New Stereo Idea - Penwraith - 04-28-2005 Any sub with that kind of power should be securely mounted above the floor facing up to the sky! With the proper tuned housing chamber to boot! New Stereo Idea - hyprlte - 05-09-2005 Thats HUGGEEE |
