Sunroof Trouble - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Sunroof Trouble (/showthread.php?tid=15384) |
Sunroof Trouble - NoiSeeVT - 04-16-2005 Hey all Just wondering with those of you with the sunroof, when you press the close button to the second spot on the switch does it close it automatically, it says it is suppose to in the manuel but mine closes but then reopens. So I open it it works fine but when I go to close it it take 2 or 3 times to get it to shut. As well it seems to sit low in the roof, its not even with the roof line is this normal? David Sunroof Trouble - Spyder01 - 04-16-2005 On the second click, it should close automatically...I had trouble with my sunroof as well. I am going to bring it in for it to be serviced again. When i open it to the vent position, it gives me this creaking/rubbing/squeaking sound which is unbearable...i had them fix it just before the winter and at that point, there was no more sounds, worked perfectly. Now that winter is over, the sound is fricken back...so im bringing it in soon and see what they say. Sunroof Trouble - NoiSeeVT - 04-16-2005 It closes on the second click but then rectract like a garage door when something is its way it opens again, is there a safety switch? David Sunroof Trouble - SVT ZX3 - 04-16-2005 Mine is flush with roof. I don't think it should be recessed at all. I know the manual tells how to reset the sunroof, but I have never tried this procedure. Sunroof Trouble - ZX5focused - 04-16-2005 im still trying to figure out my sunroof, ive only had the car for 4 months Sunroof Trouble - Spyder01 - 04-16-2005 Oh yea, now that SVT ZX3 mention it...there is a reset procedure for the moonroof. Check your manual, it should reset your roof back to factories settings. Sunroof Trouble - NoiSeeVT - 04-17-2005 Spyder01,Apr 16 2005, 12:02 AM Wrote:Oh yea, now that SVT ZX3 mention it...there is a reset procedure for the moonroof. Check your manual, it should reset your roof back to factories settings. Hey that reset worked, I found how to do it and its fully operational again :) Thanks David Sunroof Trouble - SVT ZX3 - 04-20-2005 Glad to hear it! Sunroof Trouble - ZX5focused - 04-20-2005 reset did not work for me, manual says somehting about safe mode and bring to dealer. extended warranty looks more attractive right now Sunroof Trouble - silver02svtf - 04-20-2005 NoiSeeVT,Apr 17 2005, 03:25 AM Wrote:Spyder01,Apr 16 2005, 12:02 AM Wrote:Oh yea, now that SVT ZX3 mention it...there is a reset procedure for the moonroof. Check your manual, it should reset your roof back to factories settings. Had the same problem b4 too and the reset corrected it. You also may notice on very hot days your sunroof won't open...it'll go in a safety mode thinking the motor is overheating, it'll work again when it cools down ;) . |
