Wiring For Euro Spec Taillights - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Appearance (//www.focuscanada.net/forum/forumdisplay.php?fid=21) +--- Thread: Wiring For Euro Spec Taillights (/showthread.php?tid=15664) |
Wiring For Euro Spec Taillights - MAlby7 - 03-23-2005 I found these lights and I really like them. Problem is that they are Euro Spec hence the wiring is different. Exactly what would i have to do to their wiring to make them plug and play with the stock focus wiring? Wiring For Euro Spec Taillights - ZX3TUNR - 03-23-2005 nothing really. jarro has the stock euro spec tails and he just wired them up regular. Wiring For Euro Spec Taillights - 2001 ZTS - 03-23-2005 ZX3TUNR,Mar 22 2005, 11:48 PM Wrote:nothing really. jarro has the stock euro spec tails and he just wired them up regular. How can that be the case if the reverse lamps are in the bumper in Europe? Wiring For Euro Spec Taillights - ZX3TUNR - 03-23-2005 reverse lights are over rated and stupid jarrods reverse lights are yellow as are mine till i one day hook up the lights in the bumper. Wiring For Euro Spec Taillights - 2001 ZTS - 03-23-2005 ZX3TUNR,Mar 22 2005, 07:21 PM Wrote:reverse lights are over rated and stupid :rolleyes: You must be buddies with that other guy with no front turn signals? Wiring For Euro Spec Taillights - ZX3TUNR - 03-23-2005 i got front turn signals.. Wiring For Euro Spec Taillights - guilty - 03-23-2005 If those tails can be fitted with a dual filament bulb for the red lense and a clear bulb for the clear lense, you could just wire them up the way your stock tails are. Only thing is you'll have to cut and splice to get the bulb harnesses hooked up (stock north american bulb harness' probably wont fit into those lights). Wiring For Euro Spec Taillights - paolo - 03-23-2005 guilty is correct, if they only have single filament for the bulb behind the red lens, it may be difficult to wire up. Now.. I havent messed arround with the tail light wire configuration, but I have an idea to re-use the existing wire harness and bulbs that come on the north american tail lights, just unplug the wire & bulbs only, and re-fit them to the european tail lights. you might have to do some small modifications like making the hole where the bulb goes bigger or smaller, but it should fit and work like your stock North American tails. if you want to re-locate stuff like your reverse lamps into your bumper, etc.. now thats a totally different story and I cant help you with that just yet. but try my suggestion and see if it works. That way, there is NO splicing or Cutting of any wires. Wiring For Euro Spec Taillights - MAlby7 - 03-23-2005 Oh by the way here's a shot of the rear of the lights: Wiring For Euro Spec Taillights - paolo - 03-23-2005 Malby, thanx for the pic of the rear, ny looking at those pics, it just might work. Wiring For Euro Spec Taillights - SL8RZZX3 - 03-23-2005 i have the same lights, but in chrome...........wishin' i got the black ones :angry: you have to buy new bulb sockets and they should be able to be spliced in to work North American style. I haven't done mine yet, but i got the bulb sockets from european-parts.net Wiring For Euro Spec Taillights - paolo - 03-24-2005 SL8RZZX3,Mar 23 2005, 08:25 AM Wrote:i have the same lights, but in chrome...........wishin' i got the black ones :angry: Sl8rzx3, why do you have to buy new bulb sockets? did you try the US spec sockets first and for most to see if they fit? the euro sockets only have single filament brake lights? while the north american uses Dual? wouldnt hacking the sockets/housing work? or trying the sockets from the grille bulbs to see if they work as well? could possibly work/ Wiring For Euro Spec Taillights - SL8RZZX3 - 03-24-2005 Here's what i have........... Hope this helps NA vs. european sockets ![]() |
