Gotta Problem Need Help - Printable Version
+--- Thread: Gotta Problem Need Help (/showthread.php?tid=15983)
Gotta Problem Need Help - MAlby7 - 02-16-2005
OK as you guys know I moved my system around. Now when I connect the remote wire on my system my subwoofer amp starts making this high pitched buzzing sound. I tried moving the grounds around, nothing happened. I tried taking the capacitor out of the circuit; nothing happened. Now I'm lost on what to do and I still have this buzzing sound. Someone help!
Gotta Problem Need Help - scoobasteve - 02-16-2005
have you checked if any of your wires were pinched, cut or crossed. are the wires cut to the exact length. because if your power wire is rolled up it could cause interference
Gotta Problem Need Help - NoiSeeVT - 02-16-2005
I have to agree sounds like a loose ground or a loop, all of your amps are grounded to the same location?
David
Gotta Problem Need Help - MAlby7 - 02-17-2005
All the wires are tight. My ampas are grounded at either side of the hatch but my capacitor is grounded about 5" away from my subwoofer amp. I sanded the paint down like crazy so there is bare metal in the trunk.
Gotta Problem Need Help - ANTHONYD - 02-17-2005
Are your RCA cables running near your speaker wires?
Gotta Problem Need Help - scoobasteve - 02-17-2005
are the amps screwed to the seat... try taking the amp off the seat and see if the noise is still there. My rockford amp always made a hi-pitched whining noise but its been working fine for the last 3 years.
scoobasteve,Feb 16 2005, 01:27 PM Wrote:are the amps screwed to the seat... try taking the amp off the seat and see if the noise is still there. My rockford amp always made a hi-pitched whining noise but its been working fine for the last 3 years.
[right][snapback]86871[/snapback][/right]
No the amp is screwed into a wall of mdf on the side of my trunk.
I went out again tonight and fiddled around with the system. I tried moving the grounds around, I tried disconnecting the RCA cables, and I tried removing the capacitor again. What did I achieve.....NOTHING! I noticed though that it only does this buzzing when the car is running. The 4 channel JL amp is hooked up the same way and it works perfectly fine. Also when there's a bass note the buzzing goes away for that note then comes back when there's no bass. I'm wondering if there something wrong with my amp? Should I take my amp to a JL Dealer and see what they say?
Gotta Problem Need Help - NoiSeeVT - 02-18-2005
Do you have a portable player (ie IPOD) (may need to get the earphone to RCA cable) if your near scarborough I can help you with this) If you do try to hook it up to the amp and see if this eliminates the noise. Make sure to hook it up as close to the amp as possible and do not use the RCA cables from your deck. Try this with the car running, if the noise is gone the problem is either RCA cables or the outputs on the deck. Now did you tighten the chasis grounds and alternator leads under the hood? I know on GMs this is a big problem. You may even want to upgrage the ground from the alternator to the battery and the chassis ground.
David
Gotta Problem Need Help - MAlby7 - 02-18-2005
I wrote the big three thread so ya I did the ground upgrade. I went to a JL dealer and he said to try and move the amp away from where it currently is because there might be something in the area where I have it that may be causing interference. I'm gonna try this and if this doesn't fix it then I think i'm just gonna give up and sell the car or drive it off a cliff.
Gotta Problem Need Help - Penwraith - 03-03-2005
The Barret Jackson Auction I noticed many older cars 60 70 vintage curled up the wire from the alternator someone on the show asked why? the answer was noise supression . You may need some noise inhibiter added to the mix.
Hey Malby didn't you just work on the alterntor recently?!
Gotta Problem Need Help - MAlby7 - 03-04-2005
Penwraith,Mar 3 2005, 05:38 AM Wrote:The Barret Jackson Auction I noticed many older cars 60 70 vintage curled up the wire from the alternator someone on the show asked why? the answer was noise supression . You may need some noise inhibiter added to the mix.
[right][snapback]90929[/snapback][/right]
I used the big three to improve the grounds. Once I did this the system was still mounted to the back of my seats and there was no noise. The noise occured once I moved the amp to the rear wall. When you put the hatchlid on and start driving it seems to go away. I think it has to do a lot with the cold.
I believe this because I've never run my sub when it's below 10 degrees, so I've never encountered this problem. I don't hear the noise once the car is warm inside. We'll see in the spring what happens.
Gotta Problem Need Help - Penwraith - 03-04-2005
Would the fuel pump cause problems with the signal buzzing?
