Warranty Work - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Warranty Work (/showthread.php?tid=16106) |
Warranty Work - svt_rodg - 02-03-2005 i dropped my car off at heritage to have them look at my heater fan, tranny noise, emergency brake light flickering, and cd player not working. <_< well they found that my master cylinder is leaking, will be replacing the heater fan and replacing cd player with new one. as for the tranny, the service technician is going to drive it home and try to find the problem. everything is covered under warranty. Warranty Work - ANTHONYD - 02-03-2005 I've had all those things done except the parking break light. The master sylender is a common problem. The tranny noise will most likly be gear roll over noise. And the flickering cd player is most likely a poorly soldered connection. Warranty Work - Flofocus - 02-03-2005 Yad think they would make their 'Special' vehicles a little better :huh: Warranty Work - ANTHONYD - 02-03-2005 Flofocus,Feb 2 2005, 04:13 PM Wrote:Yad think they would make their 'Special' vehicles a little better :huh: The SVT is no more "special" than the normal Focus. People paid 10k more for an updated air system and wider tires. :lol: :lol: :lol: :lol: :lol: Warranty Work - svt_rodg - 02-03-2005 i only paid 23k on the road for mine :D Warranty Work - boost til'bust - 02-03-2005 ANTHONYD,Feb 2 2005, 09:06 PM Wrote:Flofocus,Feb 2 2005, 04:13 PM Wrote:Yad think they would make their 'Special' vehicles a little better :huh: but the main thing is that svt drivers didnt waste there money on an aftermarket intake so that they can drive a 17 second sedan. Warranty Work - french_connection - 02-03-2005 boost til'bust,Feb 2 2005, 10:3 Wrote:ANTHONYD,Feb 2 2005, 09:06 PM Wrote:Flofocus,Feb 2 2005, 04:13 PM Wrote:Yad think they would make their 'Special' vehicles a little better :huh: lol, keep dreaming, your sedan focus is BETTER than a svt, didnt you know we paid 10k cuz were idiots.... btw, when my POS car break, at least I get a loaner.... :rolleyes: Warranty Work - redsvtfocus - 02-04-2005 hahha...this thread is funny....ok..let me ask you ...who was the service advisor...cause I need to drop off my car...to get the radio fix or changed also...if you can tell me who it was ...I can look for him then..! thanx.... by the way....10k more for nicer bumpers and nicer fog lamps...why not?????????? Warranty Work - silver02svtf - 02-04-2005 redsvtfocus,Feb 4 2005, 02:26 AM Wrote:hahha...this thread is funny....ok..let me ask you ...who was the service advisor...cause I need to drop off my car...to get the radio fix or changed also...if you can tell me who it was ...I can look for him then..! thanx.... ..and Variable Cam Timing & Dual-stage Inlet System Compression 10.2:1 Horsepower 170 hp @ 7000 rpm Torque 145 lb.-ft @ 5500 rpm (85% torque @ 2200 rpm) Intake Valve Dia 33.5 mm Intake Port Area increased Exhaust Valve Dia 28 mm Exhaust System 4-into-2-into-1 Exhaust Pipe 58 mm (2.28 in.) Exhaust Tip 75 mm (2.95 in.) Chrome Transaxle 6-speed manual Clutch Hydraulic actuation with Dual Mass Flywheel Driveshafts Solid (13% greater torque capacity) Chassis Spring Rate F/R 129 lb./in. (22.5 N/mm) / 157 lb./in. (27.5 N/mm) Dampers F/R Increased Low-speed damping. Decreased High-speed clamping Anti-roll bars F/R 21 mm/21 mm Tires P215 45 R17 (Z-rated) Wheels 17" SVT 5-spoke alloy Steering Power rack and pinion with tuned boost curve Brake System 4-wheel disc w/ ABS Brakes - front 300 mm vented rotor Brakes - rear 280 mm Solid Rotor Traction Control Exterior Fascia Unique honeycomb grill & round fog lamps Headlights Grey bezel surround under lens Moldings Body color bodyside and rocker Door Handles Body Color Mirrors Body Color, power, break-away, heated Rear Spoiler Rear Spoiler Unique body color Interior Instrument Cluster Titamium-color electric-luminescent faces w/160 mph speedo Front Seats Leather with woven color-keyed cloth insert. Heated. Rear Seats Added 60/40 split flip up bottom and center head rest Gear Shift Aluminum knob with leather accents Parking Brake Leather wrapped with satin aluminum release button Power sunroof Audiophile 6-disc in-dash CD changer w/ 8" subwoofer & amplifier 290watts peak power & steering-mounted audio control :P Warranty Work - redsvtfocus - 02-04-2005 hahaha...I think we are thread jacking here.... you are missing a couple.... 4 airbags and oil temp and oil press gauges!!!! Warranty Work - svt_rodg - 02-04-2005 redsvtfocus,Feb 3 2005, 09:26 PM Wrote:hahha...this thread is funny....ok..let me ask you ...who was the service advisor...cause I need to drop off my car...to get the radio fix or changed also...if you can tell me who it was ...I can look for him then..! thanx.... ask for jeff, he was very helpful and is currently checking to see if ford will replace my clutch and flywheel with new and improved parts. |
