Memory Foam? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Appearance (//www.focuscanada.net/forum/forumdisplay.php?fid=21) +--- Thread: Memory Foam? (/showthread.php?tid=16207) |
Memory Foam? - _JC_ - 01-21-2005 so i'm doing a little project i want a logo to become 3D ...would my best bet be to just cut out my logo ouy in memory foam then re cover it with vinal or fabric. any suggesions? Memory Foam? - guilty - 01-21-2005 I think that's the way it's done most of the time.. Probably depends on what you're trying to do though; the size and shapes, type of material, etc. Memory Foam? - MAlby7 - 01-21-2005 It depends. How Intricate is the logo? If it's not too bad I would do it that way. I used that carpet foam for the sidewalls in my focus. I'll post a pic as soon as I up loaded it. It may be a little tough to cut with straight lines but it's pretty cheap. I got like 2 square yards for a little over $10. Memory Foam? - _JC_ - 01-22-2005 Malby ...what kinda logo are u covering and where ? Memory Foam? - _JC_ - 01-22-2005 hopfully u can see that fine? there tape in the way but its the ford racing logo...... i need some suggestions on this i dont think i can cover it ? things i'm worries about : the ford logo has many small holes like the O...and..the d and the A in Racing Memory Foam? - MAlby7 - 01-22-2005 I'm not doing a logo I'm just covering the walls in my hatch with that stuff. I think it will be very difficult to make that logo. Reason being that if you were to cover it in pleather you would see all kinds of creases where the round parts are. That stuff I showed you may not be the easiest thing to work with, but home depot does carry similar stuff that is actually foam. It's udes for the same purpose as what my material is used for but it was double the price. Might be easier to work with though. Also the stuff I bought is at least a 1/2" thick. Memory Foam? - svt_rodg - 01-23-2005 you'll need a lot of contact cement, not sure if thats the right term, but it comes in a sprayable can. Memory Foam? - guilty - 01-23-2005 _JC_,Jan 21 2005, 05:38 PM Wrote:i need some suggestions on this i dont think i can cover it ? You're going to have to use a lot of adhesive and a really thin material so it will actually get in the small holes. You'll have to find something fairly thin and sort of stretchy so it can get in the indents without making a bunch of creases everywhere.. That's the problem of doing a complicated logo. Memory Foam? - darkpuppet - 01-23-2005 guilty,Jan 22 2005, 04:55 PM Wrote:_JC_,Jan 21 2005, 05:38 PM Wrote:i need some suggestions on this i dont think i can cover it ? vynil, a heat gun and a little TLC aught to do the trick. |
