Need Help With Dtc Codes - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Need Help With Dtc Codes (/showthread.php?tid=16330) |
Need Help With Dtc Codes - mo_focus - 12-25-2004 Hi all i just have two codes, i know one is the low batt voltage which is bc i just changed the battery but the other one i don't know what it means it gives me code DTC-d262 which means SCP Communication Bus Error, but what the hell does that mean? is this something i should be worrying about? i will try to reset the codes tonite and i'm sure the battery low voltage will go away but will the other one stay?and is it something to worry about? Merry christmas all Mo Need Help With Dtc Codes - boost til'bust - 12-29-2004 I wouldnt worry about it. Might just be your scanner....what scanner did you use? have you used this scannner before? |
