Wiring - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: The Basics (//www.focuscanada.net/forum/forumdisplay.php?fid=25) +--- Thread: Wiring (/showthread.php?tid=1643) |
Wiring - patrick23 - 04-17-2009 How do you bring a wire from the engine bay to the cabin? is there any opening that I can use easily? like a hole with grommet or something like that? I want to wire some fog lights and I can't find a ready made hole to bring the wire in. Wiring - ZX3_2NV - 04-18-2009 I beleive there is a hole near where the steering colum enters the engine bay or above the break i think under the carpet Wiring - Spinal - 04-18-2009 there is one in the engine bay around where the steering wheel is on the of the door. Wiring - Scorcher000 - 04-18-2009 I just drilled a hole threw and its just behind the carpet and right of the dead man. It will come out underneeth the fuse box if you have 2005 up. Use a 1/2 in wood spade bit. It's all plastic so no prob. |
