Remote Starter Bad For Car? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Remote Starter Bad For Car? (/showthread.php?tid=16477) |
Remote Starter Bad For Car? - mysterygirl - 11-26-2004 Just wanted to know if installing a remote starter on my car would be potentially bad for my car? Will it mess up my ECU or any other components of the car? Or is that just old news? I have a ZX3 Manual transmission. Thanks! Remote Starter Bad For Car? - BerinG - 11-26-2004 mmm. I wasn't aware that a remote starter would caus any trouble but would be interesting to know if it does as i plan to install one on my manual zx3 .. not sure why it would though Remote Starter Bad For Car? - mo_focus - 11-26-2004 just make sure you get something good and not cheap. Compustar is really good and there is no way of false starts with it. Remote Starter Bad For Car? - meford4u - 11-26-2004 Last time I looked, they stopped making remote starters/installing them on cars with a manual transmission. Something they called "lock and load". Remote Starter Bad For Car? - dBlast - 11-26-2004 Does the remote starter shift the car into nuetral and depress the clutch? I'm not sure if it's true with the focus but some manual cars don't start without the clutch in? :blink: Remote Starter Bad For Car? - scoobasteve - 11-26-2004 theres a switch hooked to the clutch switch that allows it to remote start. IMHO compustar is the best becauase you have to shut off the car in a special way for it to arm the autostart. Remote Starter Bad For Car? - 2001 ZTS - 11-26-2004 The only "bad for car" concern is excessive idling "they" say you shouldn't do it for more than 30 seconds but we all know it takes many minutes before you can even see out the windows on a cold day. Remote Starter Bad For Car? - tdot-zx3 - 11-26-2004 youll be fine. Remote Starter Bad For Car? - LOFOCI WAGON - 11-26-2004 I have had one almost since I have owned my wagon! I have the 5 speed and I have had no problems. You should buy a quality car started and you will also need the security bypass modual and get a reputable installer. The procedure to activate the starter is different than an automatic but it's not a problem. I have a Prostart and it works great! Remote Starter Bad For Car? - svt_rodg - 11-26-2004 i had a remote starter on my mtx sho and didn't have any problems what so ever. with my starter, you had to program the car before shutting it off. the program was just leaving it in neutral and pressing a button. the lights would flash, take the key out (the car will still be on), once out of the car press button and the car will shut off. Remote Starter Bad For Car? - SVTZX503 - 11-26-2004 I have the compustar and haven't had any problems with it. You need to leave it neutral with the hand brake on in order for it to start. It has a two way pager so you know if it is running and a range of 5000 feet. It also has a setting so you make it start every so many hours. Mine includes an alarm so it is worth the money. I paid $800 for mine installed which included remote door lock/unlock and for the hatch to be open. Make sure you get a pro to install it. Compustar also covers warrenty if it is the cause of a problem with your car. Remote Starter Bad For Car? - LOFOCI WAGON - 11-26-2004 svt_rodg,Nov 25 2004, 11:29 AM Wrote:i had a remote starter on my mtx sho and didn't have any problems what so ever. with my starter, you had to program the car before shutting it off. the program was just leaving it in neutral and pressing a button. the lights would flash, take the key out (the car will still be on), once out of the car press button and the car will shut off. SVTZX503,Nov 25 2004, 11:38 AM Wrote:I have the compustar and haven't had any problems with it. You need to leave it neutral with the hand brake on in order for it to start. It has a two way pager so you know if it is running and a range of 5000 feet. It also has a setting so you make it start every so many hours. Mine includes an alarm so it is worth the money. I paid $800 for mine installed which included remote door lock/unlock and for the hatch to be open. Make sure you get a pro to install it. Compustar also covers warrenty if it is the cause of a problem with your car. Same as what these 2 have said! |
