Shift Linkage - Printable Version
+--- Thread: Shift Linkage (/showthread.php?tid=16797)
Shift Linkage - BerinG - 10-01-2004
Ok I know that you need to play with the orange stuff to adjust it.. shorthen it or not.. everyone says that.. but what exacly do i WANT to be doing.. make it shorter? make it longer? doe sht eshifter have to be on the right.. left, center, corner..
anyway its all these details that im missing.. have trouble putting it in gear.. everyone says to fix the linkage.. but the question is HOW do i fix it.. what are the procedures.. i know how to make the changes, just not what changes im trying to make.. thanks!
Shift Linkage - BerinG - 10-02-2004
bahhh.. ill kick you all in the nuts!
Shift Linkage - S2 - 10-02-2004
Not sure if this is what your looking for but I thought I would post it anyway....
http://www.focushacks.com/index.php?modid=49
yeah i found that later last night too.. im just not sure how that is adjusting anything.. you put it in neutral.. unclip the cable.. then.. have someone put it in neutral.. and then clip back the cables?
you know what i mean? still isn't really clear what I have to do here.. and where do the adjustements come in hehe.. and the 2 images are the same thing..
thanks though!
*edit ok it say to put the "shifter arms" in neutral.. but if i just put the shifter in neutral.. shouldn't the arms be in neutral already? and how do i know what is the neutral on the control arms
