Need Material Choice Help - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Need Material Choice Help (/showthread.php?tid=16904) |
Need Material Choice Help - MAlby7 - 09-17-2004 I'm thinking of making a wood floor for my hatch in the trunk part. I want to cut out a square in the top left corner so my sub box could sit in it and not move around. I also want to have a door that I can open and access the spare tire if necessary. What material should I use to make the floor out of? Wood? What type? Thickness? Help me out guys! Need Material Choice Help - 01-yellow-ZX3 - 09-17-2004 1/2" MDF? Need Material Choice Help - MAlby7 - 09-17-2004 01-yellow-ZX3,Sep 16 2004, 06:01 PM Wrote:1/2" MDF?But I'm taking all things into consideration. I like the idea of a 1/2" or 3/4" depth. But I'm also worried about any water that may be spilled in my trunk say from an umbrella or such, also will MDF stand up to the test of time? I will also be covering it with either carpeting or speaker box material, but something durrable none the less. Also weight preservation is a slight issue. Keep the ideas coming. Need Material Choice Help - 01-yellow-ZX3 - 09-17-2004 I don't think a small amount of water will hurt the mdf, especially under carpet or anything. I made a dish mount for a friend's apartment. And it mounted to his balcony with 2 pieces of MDF. He's since moved, and reinstalled the same mount, and the MDF is still fine after a year of being out in the elements and snow etc. Need Material Choice Help - Raine - 09-17-2004 umm... MDF = Compressed cardboard = sponge when wet? Plus it's heavier than ply. If I were you, I would make it out of 1/2" ply. No need to go 5/8 or 3/4... think about how thick the backing is now. It rests on the metal, and you've got all the support you need. You could even get away w/ 3/8 and put a second layer to mount the sub box in. So it would look like the following: ____________| |_____________| | Need Material Choice Help - 01-yellow-ZX3 - 09-17-2004 You could also treat the MDF, but its inside a trunk, how wet can it get... MDF doesn't act like a sponge like you'd think. And its cheapppp. A 2X4' sheet at Rona is only $8, 4X4 is $13ish (both 1/2") and they'll cut it for free. Need Material Choice Help - Raine - 09-17-2004 MDF swells like crazy if any moisture touches it's sides and it's not treated. I sell the stuff. A 4x8 sheet of MDF is gonna run you about the same as a 4x8 of ply. Unfortunately, we don't see 4x4 except in 1/4" ply Need Material Choice Help - meford4u - 09-17-2004 Quit screwing around with MDF and go to the lumber yard and ask for a sheet of MARINE GRADE PLYWOOD. You can get it wet al you want, it is used for subflooring for boats. I work with wood all the time and this is what you want. I'm done here Need Material Choice Help - Raine - 09-17-2004 Marine grade's good, so's pressure treated or fire-rated, but realistically, if you use a rubberbacked carpet, you can put any kinda ply Need Material Choice Help - MAlby7 - 09-17-2004 Raine,Sep 16 2004, 06:56 PM Wrote:So it would look like the following:Al, I don't exactly understand what I'm looking at here! Need Material Choice Help - 2001 ZTS - 09-17-2004 meford4u,Sep 17 2004, 12:06 AM Wrote:Quit screwing around with MDF and go to the lumber yard and ask for a sheet of MARINE GRADE PLYWOOD. You can get it wet al you want, it is used for subflooring for boats. I work with wood all the time and this is what you want.Just what I was going to say. Marine Grade is so good that it is not just used on recreational boats but commercial ships as well. |
