Is There A Udp Install Guide Anywhere? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Is There A Udp Install Guide Anywhere? (/showthread.php?tid=16992) |
Is There A Udp Install Guide Anywhere? - Raine - 09-03-2004 Bought a 2 piece UDP kit today, have no clue how to install it. Anyone know of a good tutorial? Or better yet, anyone wanna help? Should be getting it in a week or so. Heard it can be quite easy if done right. Any advice woudl be appreciated :) Thanks Is There A Udp Install Guide Anywhere? - hardk0re - 09-03-2004 http://www.myfordfocus.com/how-to/focussport-udp.htm This is for the single piece but may help you out a bit. There is a small guide that you may need to grind off when you install the new crank pulley to prevent the new belt from catching... Is There A Udp Install Guide Anywhere? - S2 - 09-03-2004 http://www.focusworld.net/forum/viewtopic.php?t=1066 Awesome writeup..... plus it's for the Focus Central..... Is There A Udp Install Guide Anywhere? - ZX3TUNR - 09-03-2004 I think the how to on myzx3.com is the best. Its not to bad of a job. Actually really easy once you figure it out. Took me 4 hours to do first time now im sure next time it well take an hour to hour and 1/2.. Have patience when taking off some of the bolts. I remember one bolt came off easily but you could only turn it so much and seemed like it took for ever.. Is There A Udp Install Guide Anywhere? - dad - 09-04-2004 took me less than 45 min........then I had to put the stock back on cause stupid SHM shipped with the wrong belt....fuctards 70 min. ....udp in ,udp out stock pulley back in....easy job Is There A Udp Install Guide Anywhere? - Flofocus - 09-04-2004 dad,Sep 3 2004, 02:39 PM Wrote:took me less than 45 min........then I had to put the stock back on cause stupid SHM shipped with the wrong belt....fuctardsYou like shopping there, heh? :lol: Is There A Udp Install Guide Anywhere? - ZX3TUNR - 09-04-2004 witht he fc 2 peice pulley you do have to do some griding on the one peice so the belt dont rub. Is There A Udp Install Guide Anywhere? - Raine - 09-04-2004 hardk0re/s2,Sep 2 2004, 11:18 PM Wrote:There is a small guide that you may need to grind off when you install the new crank pulley to prevent the new belt from catching...Thanks for the links. Will I still need to cut this guide? Because as per my understanding these pulleys use the stock belt? Is There A Udp Install Guide Anywhere? - rallyfocus - 09-07-2004 You'll see exactly what you need to grind down when you rmove the stocker. It's the black plastic thing behind the pulley. I used a bench grinder because it was close to me and it worked fine. I just took off the FC and put the stocker back on in less than 15 min :D Is There A Udp Install Guide Anywhere? - Raine - 09-07-2004 I have an angle grinder, so it's not a problem. Just wasn't sure if it was still a necessary step. :) Thanks for the help guys. Still wouldn't mind a hand putting them in tho :P |
