Oil Spewing - Printable Version
+--- Thread: Oil Spewing (/showthread.php?tid=1707)
Oil Spewing - blue_light - 04-08-2009
i have oil spitting out on the drive belt causing major slipping any ideas what it could be?
Oil Spewing - ZTWsquared - 04-08-2009
blue_light,Apr 7 2009, 11:33 AM Wrote:i have oil spitting out on the drive belt causing major slipping any ideas what it could be?
[right][snapback]284492[/snapback][/right]
Leaking valve cover - cracked block - could be a lot of things - first thing to do is stick your head in there and try to see where it's coming from - in any event, you'll need to provide more info or pics for anyone on here to be able to help.
Oil Spewing - ANTHONYD - 04-08-2009
Im guessing valve gasket. Quite common with the fofo.
Have a good look in there there. A cracked block wouldn;t be good at all.
Check under your oil cap as well. If it's milky.... start looking for a scrap yard near by.
Oil Spewing - NOS2Go4Me - 04-08-2009
It's those DAMN TERRORISTS AGAIN! BIN LADEN AND HIS ILK! :lol: :rofl:
Seriously... if the oil is coming out topside, it's possibly a valve cover gasket.
Can you see which pulley is getting hit? Or is it just the belt directly?
Oil Spewing - Gabriel - 04-08-2009
valve cover or a seal leaking ? seals are a common problem
Oil Spewing - Burnin21 - 04-08-2009
A leaking valve cover would get your timing belt first wouldnt it? Sounds like your seal is gone on your oil pump. I'd look down there first.
Burnin21,Apr 7 2009, 06:02 PM Wrote:A leaking valve cover would get your timing belt first wouldnt it? Sounds like your seal is gone on your oil pump. I'd look down there first.
[right][snapback]284532[/snapback][/right]
yep , just as I thought
Oil Spewing - blue_light - 04-09-2009
thanks
