Need Help - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Need Help (/showthread.php?tid=17070) |
Need Help - mo_focus - 08-22-2004 Got two CEL codes on my car, i just want to know if anyone had these codes before and what was the remedy? thanks Mo P1124 - Throttle Position (TP) Sensor Out of Self-Test Range The TP sensor circuit is monitored by the PCM for an out of range TP rotation angle (or voltage) input. If during key ON engine OFF or key ON engine running the TP rotation angle (or voltage) reading is less than 13.27% (0.66 volt) or greater than 23.52% (1.17 volts), the test fails. Binding or bent throttle linkage TP sensor not seated properly Throttle plate below closed throttle position Throttle plate/screw misadjusted Damaged TP sensor Damaged PCM A TP PID (TP V PID) reading not between 13.27 and 23.52% (0.66 and 1.17 volts) in key ON engine OFF or key ON engine running indicates a hard fault. P1709 - Park/Neutral Position Switch Out of Self-Test Range The DTCs indicate that the voltage is high when it should be low. PNP/CPP circuit short to PWR Damaged PNP or CPP switch PNP/CPP circuit open in the SIGRTN Damaged PCM When exercising either the PNP or CPP switch the voltage should cycle from 5.0V to low |
