Plug Wires - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Plug Wires (/showthread.php?tid=17286) |
Plug Wires - wadem - 07-07-2004 I was thinking about getting a set of plug wires (more for looks than anything). So I was wondering would there be any difference between steeda.ca 8mm wires for $53.99 and fordracing 9mm wires for $60 cnd. Would new wires really make any difference other than looks? Thanks Plug Wires - meford4u - 07-07-2004 Upgrading your wires from stock will make a difference in the amount of spark that travels to your plugs. Update them both at the same time and your engine will have a cleaner burn. There are many different plug wires out there, and I am not going down the road again as to who makes the best wires, but just upgrading from the stock plugs after they have had a few miles on them will be beneficial to your engine. Have fun It's easy changing the plugs and wires in the Focus. Plug Wires - Flofocus - 07-07-2004 I have the FR ones. Revs smoother I guess....hard to tell with such a mod. Plug Wires - wadem - 07-08-2004 Which plug would you suggest I use? Right now they are stock with 26000km on them. Plug Wires - Flofocus - 07-08-2004 wadem,Jul 7 2004, 10:22 AM Wrote:Which plug would you suggest I use? Right now they are stock with 26000km on them.Im still running the stock plugs...going with one step colder when boosted Plug Wires - NOS2Go4Me - 07-08-2004 Be careful if you have the SPI... I got shafted when I ordered my first set. The only pairs that fit the SPI are the FocusSport 8mm wires specifically labelled "for the SPI" and certain aftermarket Ford Ranger 8mm wires will fit. The SPI has a narrower bore down to where the sparkplug is seated, and ZETEC wires will NOT work. |
