Starter Problem? - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Starter Problem? (/showthread.php?tid=1749) |
Starter Problem? - Flofocus - 04-02-2009 So the new owner called me again... car wont start, makes 1 click fromt he starter area and thats it. I thought it would be the battery, but we checked with the volt meter, its good. Anybody have the starter go on them and have similar symptoms? Starter Problem? - Scourge - 04-02-2009 Did you check the battery while trying to crank? I've had batteries read fine with no load but the voltage would drop to next to nil as soon as you applied load. -George Starter Problem? - Burnin21 - 04-02-2009 Check that battery cables too. Those buggers are sensative. Also check you grounds sometimes that prevents it from startin. I've never had a starter go on me, but just about everything else in the car! lol! Starter Problem? - Focus man. Focus. - 04-02-2009 A failing battery can have 12V but have 0 Amps. I would have him get the battery load tested. That would give you an answer on the true condition of the battery. Starter Problem? - Flofocus - 04-03-2009 thanks guys....ill tell him to get it load tested. Starter Problem? - ANTHONYD - 04-03-2009 why is the new owner calling you with problems? I thought when you sell a car, it becomes the buyer's problem? Starter Problem? - ZX3_2NV - 04-03-2009 u should tell him to sign up and ask us himself Starter Problem? - Flofocus - 04-03-2009 ANTHONYD,Apr 2 2009, 11:28 AM Wrote:why is the new owner calling you with problems? Beleive it or not, Im actually a nice guy. :rolleyes: Quote:u should tell him to sign up and ask us himself already did, dont think he uses a computer too much. Starter Problem? - meford4u - 04-03-2009 Flofocus,Apr 2 2009, 11:20 AM Wrote:I don't believe you. Prove it.ANTHONYD,Apr 2 2009, 11:28 AM Wrote:why is the new owner calling you with problems? Starter Problem? - Flofocus - 04-03-2009 Prove what? Anyways... Battery is fine, eveything checked out good. We bump started it yesterday and the car started. Told him to order a starter and I'll install it on Sunday. |
