If I Do Decide To Do The Install Myself... - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on I.C.E. (//www.focuscanada.net/forum/forumdisplay.php?fid=23) +--- Thread: If I Do Decide To Do The Install Myself... (/showthread.php?tid=17507) |
If I Do Decide To Do The Install Myself... - MAlby7 - 05-29-2004 I need to know exactly what I need for the install. I am talking about accessory parts here. Just in case you guys need the reference of what pieces I have in my car here's the list: DECK: PIONEER 7500MP SPEAKERS: INFINITY 6802CF (6"x8") SPEAKER AMP: JL AUDIO 300/4 SUB AMP: JL AUDIO 500/1 SUB: JL AUDIO 10W7 WITH CUSTOM SEALED BOX From all the stereo store guys I've talked to, I've understood the follwoing: - I could use 4ga wire as a power wire to power my two amps that take 4ga each. - My speakers wire should be 14ga - I need a ASN (or ALS) fuse with a blade fuse in it. - I need a distribution block to split the power wires to the amps. - "The Big 3" would be beneficial. What other words of wisdom do you guys have for me? If you guys could compose a list for me of exactly what I have to go buy before the install (ie. wire type, gauges, etc), and where I could buy it, it would be greatly appreciated. If I Do Decide To Do The Install Myself... - FocusGuy7476 - 05-29-2004 some other things you might need are: 1. RCA Cables 2. Adpater Plate for head unit 3. Wiring Adapter for focus 4. Power Wire and Fuse holder 5. Speaker Wire if anyone else can think of items that need to be added to list pls add them and help MAlby7 out. If I Do Decide To Do The Install Myself... - redsvtfocus - 05-29-2004 The ground wire must be the same size as the power one...ground distributor... the RCA cables .. they are the key players here to...good quality ones... .......solder.....pliers... remote wire...not thaaat big.. if someone can come up with something else...?!! good luck ;) If I Do Decide To Do The Install Myself... - MAlby7 - 05-29-2004 Well right now I have 3 RCA Cables but I'm going to replace one because I don't think it's that good. So I have the following: 1. RCA Cables 2. Adpater Plate for head unit 3. Wiring Adapter for focus 4. 2 Good RCA cables 5. Remote wire (not sure if it's ok) Need larger diameter power wire and ground wire. I already have a system in my car with a 4 channel amp and speaker wire, so I'm not exactly sure what I can change and what I can keep. If I Do Decide To Do The Install Myself... - dansmurf - 05-29-2004 Also need adapter for antenna plug. :) If I Do Decide To Do The Install Myself... - MAlby7 - 05-30-2004 dansmurf,May 29 2004, 01:52 AM Wrote:Also need adapter for antenna plug. :)Got that. If I Do Decide To Do The Install Myself... - redsvtfocus - 05-30-2004 got the ground distribuitor??? that one helps a lot.... If I Do Decide To Do The Install Myself... - MAlby7 - 05-30-2004 redsvtfocus,May 29 2004, 10:59 AM Wrote:got the ground distribuitor???To tell you the truth I don't even know what that is! |
