65mm Pro-m Maf - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: 65mm Pro-m Maf (/showthread.php?tid=17548) |
65mm Pro-m Maf - darkpuppet - 05-26-2004 This little piece of kit showed up in my mail today: yes folks, a 65 mm Pro-M MAF!!! BOOYAH! <a href='http://www.darkpuppet.com/images/maf/maf.jpg'> ![]() This bad boy should bolt onto my supercharger inlet and cone filter without any serious modifications necessary... the piece is cast aluminum, most likely a Ford Ranger part, with a pro-M MAF calibrated to 42# injectors. The flow sheet shows 42lbs of air/minute at 4.517, so it'll definitely handle my HP needs. The only problem I forsee is that the o-ring that seals the sample tube in the housing, actually drops below the inside wall of the housing <a href='http://www.darkpuppet.com/images/maf/maf_inside.jpg'> ![]() So I'm going to pull that o-ring (so it doesn't disintegrate over time and get sucked up the supercharger), and use a little liquid gasket to seal it up nice and tight. Of course, I'm still waiting on my dataloggig software so I can install this thing (considering I ordered the datalogging software 3 days before the MAF while I researched MAFs)... almost there.... 65mm Pro-m Maf - microbunny - 05-26-2004 All that doesnt mean s**t to me...but COOL!!! all I wanna know is can I have a ride??? 65mm Pro-m Maf - Paparoach - 05-26-2004 Almost there sounds like tonnes of fun :D 65mm Pro-m Maf - meford4u - 05-26-2004 Ah Steve, old buddy ole pal, Were did you get it? I am looking for the same part--same problem as you. Pm me if you like as I would also like to know $$$$$ 65mm Pro-m Maf - Flofocus - 05-26-2004 <a href='http://img25.photobucket.com/albums/v76/Flofocus/Picture_053.jpg'> ![]() Got mine with 42 Lb Injectors from CFM....came just under $500 for everything. 65mm Pro-m Maf - Flofocus - 05-26-2004 Paparoach,May 25 2004, 02:21 PM Wrote:Almost there sounds like tonnes of fun :Dyou dont even understand :lol: :ph34r: 65mm Pro-m Maf - darkpuppet - 05-26-2004 Flofocus,May 25 2004, 06:50 PM Wrote:niiice... that's the 70mm unit, right? that inlet side looks HUGE!!! your outlet is just over 3" outside diameter while mine is 2.98".. perfect for the 3" flex hose going from the maf to the supercharger. I can't wait to get this all together and tuned properly... so what parts are you still waiting on, or are you ready for assembly? 65mm Pro-m Maf - meford4u - 05-26-2004 You know what Steve, I am just going to sit back and learn. Whether you are bang on the first time or hit roadbumps along the way. Just keep posting and I will learn from all of you and then one day [SIZE=medium]ZOOOOOOOOOOOOOOOOMMMMMMMMM Thanks for the info flo. If you did get the parts In Canada puppet, let me know please. I see Steeda has it for $285 Can. Answering my own questions is like talking to myself. Don't know where to go with that 65mm Pro-m Maf - darkpuppet - 05-26-2004 I ordered this from the states... beats dealing with the half-clued folks you find at many canadian shops. I didn't have time or money to keep trying for properly sized MAFs... I'm going by engineering diagrams, and ordering straight from the source (pro-flow in this case). Flofocus.. one thing I see in your pics, is that the o-ring hangs into the main MAF body as well.. you may want to pull the MAF and use some liquid gasket to make sure she's sealed properly. I can pretty much block one end of my MAF, and breath normally through the other end, as there appears to be a lot of leakage between the sample tube and MAF body--something I'm sure is not good in the long run. 65mm Pro-m Maf - Flofocus - 05-26-2004 See Steve now your confusing me....haha... On Fj I posted about this.... Look at the pics, well the other side has another 1/2" added to the diameter. But on the MAF it says 65mm....its clearly bigger on both sides. :huh: 65mm Pro-m Maf - darkpuppet - 05-26-2004 Flo, you gots the 70mm unit.... I read (and posted a reply to) your post on [FJ]... you should still be fine. [edit] note that the size of the MAF is measured at the narrowest point...[/edit] |
