Scream Demon - Printable Version
+--- Thread: Scream Demon (/showthread.php?tid=17576)
Scream Demon - qtgino - 05-21-2004
Hey has anybody installed a screaming demon coilpack and wires. Is it worth it?
Scream Demon - hardk0re - 05-21-2004
If you know why you want it, then yes its a good product and is worth the money. If you think its ging to give you more power then its probably not worth it for you.
If your going to go to Dasilva for a dyno it sure will help give you better tach readings :P
I know I'm going to get any power gains, but I heard is supposed to give a better idle and smoother acceleration and hopefully a better gas milage.
Scream Demon - fokuz - 06-01-2004
qtgino,May 21 2004, 01:49 PM Wrote:I know I'm going to get any power gains, but I heard is supposed to give a better idle and smoother acceleration and hopefully a better gas milage.
Not always, its actually been proven to be a waste of money. Save up for a nice TB and intake. That will do the justice.
Also if you want a nice idle I would look in to http://www.focussport.com wire plugs, they have the lowest OHM for more actual power and better idle & gas milage :ph34r:
