Cel After Installing Speedhut Gauges. - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Canadian Focus Community (//www.focuscanada.net/forum/forumdisplay.php?fid=3) +--- Forum: Focus Talk (//www.focuscanada.net/forum/forumdisplay.php?fid=18) +--- Thread: Cel After Installing Speedhut Gauges. (/showthread.php?tid=17663) |
Cel After Installing Speedhut Gauges. - Zoom - 05-07-2004 This is my second set of speed hut gauges and this time after installing them I got the CEL to come on?!?!? What the heck? I must admit this installation was even smoother than the first. But why the CEL? Cel After Installing Speedhut Gauges. - guilty - 05-07-2004 Hmmm.. same thing happened to Bort when we installed his. Mine were fine though. Did you start your car with the gauge cluster removed? Cel After Installing Speedhut Gauges. - Paparoach - 05-07-2004 That is a weird one...got me :unsure: Cel After Installing Speedhut Gauges. - Focused - 05-07-2004 try making sure the harness is plugged in correctly at the back of the cluster.... other than that... sounds like a coincidence Cel After Installing Speedhut Gauges. - 2001 ZTS - 05-07-2004 Do that self test thing. Cel After Installing Speedhut Gauges. - ZX3TUNR - 05-07-2004 lol my gauge story is brutal. i dont evenw ant to explain. 2 most crappy things that happened to me. The needles are not exact spec. had to take them of from when I put in my old gauges. then when i installed the new gauges i used a glue to hodl them down better but then i realized i used the wrong clue and it ate away at the gauge and now some spots dont light up. Now I gotta find time so I can rip it all out againa nd re sauder the coonections. Cel After Installing Speedhut Gauges. - Bort - 05-07-2004 Yeah my engine light is on too.... piece of crap.... oh well. least i know its something i did, but now i'll never know if i actually have a problem with it or not lol Cel After Installing Speedhut Gauges. - Zoom - 05-07-2004 I got it. I turned my car on without the cluster in place. Just reset the ecu (remove black terminal for 5 min, then recconnect) voila. no more light. Gauges look sick. Cel After Installing Speedhut Gauges. - Bort - 05-08-2004 They went away? Ok so I gotta reset the ecu.. what black thing do i remove, the whole cluster again? Cel After Installing Speedhut Gauges. - Zoom - 05-08-2004 Bort,May 8 2004, 07:10 AM Wrote:They went away? Ok so I gotta reset the ecu.. what black thing do i remove, the whole cluster again?Remove the negative terminal off your car battery dude. Leave it off for like 5-10 min. ( I took it off long enough to have two cigarettes) put it back on, started the car, and voila, no check engine light! :D PS: Thanks DD1 for the idea. Cel After Installing Speedhut Gauges. - Bort - 05-09-2004 sweet thanx, i'll have to do that tomorrow |
