Cai/strut Bar Rubbing - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Cai/strut Bar Rubbing (/showthread.php?tid=17741) |
Cai/strut Bar Rubbing - FociS8nt - 04-12-2004 hey just wondering if this might cause anything bad ...they aren't hittin each other anymore i lowered the strut bar so now it is just a constant pressure on the MAF pressing the CAI pipe back ...i dunno check it out seee if anyone has any thoguhts on it... <a href='http://img26.photobucket.com/albums/v77/focis8nt/trouble.jpg'> ![]() Cai/strut Bar Rubbing - j3rt - 04-12-2004 i can't tell what's what. too much bling. jk Cai/strut Bar Rubbing - fallen32 - 04-12-2004 Hey if you can I would move the strut bar the enigne movement while driving will knock the MAF sensor and with time might cause you some problems since they are sensitve to some degree and in the end it will cost you a pretty penny to repalce. Fallen. Cai/strut Bar Rubbing - naz - 04-12-2004 if something is hitting the MAF sensor you definitely want to move something so there is no contact Cai/strut Bar Rubbing - FociS8nt - 04-12-2004 yeah see but its not hittig it they just sit against tightly?? Cai/strut Bar Rubbing - Zoom - 04-12-2004 Get a small piece of soft foam and insert it between the two, the preassure of the two against each other will hold it in there, but it will make sure that nothing gets "knocked" too hard and there shouldn't be any issues. Cai/strut Bar Rubbing - D-Dub - 04-12-2004 The soft foam will adjust to the imprint of the bar and wont cusion anyting the pressure will still be there. Soft foam only works if there is about half a centimeter of room to play so if it does move it wont hit the plastic and crack it. If you can afford to pay for a new maf every time you break leave it, but put it this way the price you pay for the brace and the new maf after the other ones break is it really worth the bar? Cai/strut Bar Rubbing - LOFOCI WAGON - 04-18-2004 Hey, that usually happens when you buy a generic strut bar like a Ractive one! I have know problems with mine as it is from Focus Central and is fitted for the Foci! ;) |
