Rear Camber Kit Install - Printable Version +- FocusCanada Forums (//www.focuscanada.net/forum) +-- Forum: Technobabble (//www.focuscanada.net/forum/forumdisplay.php?fid=4) +--- Forum: Focus on Performance (//www.focuscanada.net/forum/forumdisplay.php?fid=22) +--- Thread: Rear Camber Kit Install (/showthread.php?tid=17758) |
Rear Camber Kit Install - j3rt - 04-04-2004 I will be picking up the Steeda kit soon. I understand the instructions come with it. I was wondering if anyone has the instructions now though, in pdf or somethin, they could send me. I'd like to read through it before i buy a kit. thanks Rear Camber Kit Install - Blackzx3 - 04-05-2004 I can post them later. They go something like this Take out bolt Grind off welded on nut insert bolt align Rear Camber Kit Install - j3rt - 04-11-2004 sounds easy enough Rear Camber Kit Install - bigman - 04-12-2004 if the bolt isnt seized yes it should be that easy. |
